Old Porch Tiles - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-16-2017, 08:07 AM   #1
Rewards Points: 20
Old porch tiles
Have to replace wrought iron columns/railings on 1971 porch. Tile is loose/cracking. Is it best to retile then replace columns or secure new columns directly to concrete porch?
fuzzybear is offline   Reply With Quote
Old 04-16-2017, 08:20 AM   #2
Rewards Points: 14,020
Re: Old porch tiles
I'd tile then install the new post and rails.
What are you replacing them with?
Old 04-16-2017, 08:22 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,274
Re: Old porch tiles
Pull the rails, re-tile, then reinstall the railing.
If you tile up around the sides, you will create a basin effect and rot out the railing.
Be sure to mark out and reinforce where you are going to re-attach the railing for the most secure mounting possible.
Old 04-16-2017, 08:55 AM   #4
Rewards Points: 20
Re: Old porch tiles
Problem is the columns are supporting the corner of the roof over the porch. I would think direct to concrete would be strongest instead of relying on tiling to hold up roof. Could try to mitigate basin effect.
Old 04-16-2017, 09:16 AM   #5
Rewards Points: 20
Porch
Old 04-16-2017, 10:22 AM   #6
Re: Old porch tiles
Well...doesn't look like you are building it up here. That would flatten the pitch of the roof and create issues. I guess you are going to have to tile up to it, but be sure to drill for some weep holes and drainage pathways around them.
Concrete covered porch sleeper system questions TyWebb Building & Construction 2 06-05-2015 05:31 PM
How to Properly Support a Sinking Porch hotzpacho Building & Construction 21 07-24-2014 09:30 AM
Porch posts not under beam Cdwjr Carpentry 3 05-20-2014 03:44 AM
loads for 2 story covered porch deatra1994 Building & Construction 3 04-10-2014 10:24 AM
Need to replace 4 3x3 ceramic tiles around shower. babaganoosh Tiling, ceramics, marble 1 12-28-2010 08:40 PM
