Old House Suprises - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-18-2010, 02:20 PM   #1
Old house suprises
No secret that old houses have plenty of surprises. Removed some bad wood under my overhang and found what was the original downspouts. They are about 6 inches back from the roofline edge. Just curious how it was possible that the downspouts were originally ON the roof. Maybe my roof line has been extended at some point or was that typical of houses built in the 1920? The wood the pipe disappears into is not the roof decking.
Mike in Arkansas is offline   Reply With Quote
Old 09-18-2010, 02:40 PM   #2
I'm definitely not a pro but I would suggest that you probably originally had "yankee gutters" which are gutters built into the roof. At some point they were probably shingled over. Google it and you will see what I am talking about. My house has them and the downspout comes right down through the roof overhang. I have read that they have a tendency to leak over time which may be what caused the water damage to your roof overhang and perhaps it is why they were shingled over.
jerseyguy1996 is offline   Reply With Quote
The Following User Says Thank You to jerseyguy1996 For This Useful Post:
Mike in Arkansas (09-18-2010)
Old 09-18-2010, 05:10 PM   #3
thanks Jerseyguy. That's it. Never heard of them before . That would also explain why my roof pitch levels out toward the ends.
Old 09-19-2010, 08:00 PM   #4
remodeling pro
Jerseyguy is dead onabout what you are seeing. As stated they were very prone to leaking, and with the transition to faster and cheaper building practices, they quickly fell out of favor. As you can imagine, they were labor intensive to install correctly and required a true roofing and sheet metal mechanic, not just a modern "shingle nailer".
troubleseeker is offline   Reply With Quote
Old 09-19-2010, 08:38 PM   #5
I had an old house once that had a similar arrangement.
In this case, there was a holding tank in the attic and its overflow came out the soffit.
The idea was that the gutters ran into a tank in the ground. This water would then be hand pumped up into the attic tank. A water pipe was run from the attic tank down to a sink somewhere. Having water stored over-head provided pressure for distribution.
Old 09-20-2010, 03:03 AM   #6
Another possibility is that your home had wooden gutters, and they were boxed into soffits at some later remodel. This was the case with my home.
1910NE is offline   Reply With Quote
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 08:18 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
New house drywall DISASTER pharm07 Off Topic 13 03-25-2011 03:24 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
