Old Electrical Outlet? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-03-2014, 01:01 PM   #1
Old electrical outlet?
Hi,
I am in the process of changing an old light fixture in the bathroom. When I attempted to take off the old fixture, this is what I found behind the wall. It looks like some sort of old wire insulation. Is this something I have to remove or have retired past what is showing or can I just put a new fixture on? The house is 60 years old and the wiring is probably the same age. I attached two pictures.
Thanks,
Nikki
Old electrical outlet?-image-2989721072.jpg   Old electrical outlet?-image-1163843273.jpg
Knikki39 is offline   Reply With Quote
Old 01-03-2014, 01:13 PM   #2
joed's Avatar
Rewards Points: 11,534
Put up a new fixture. Looks fine to me. I can't tell if there is a ground but that is not super important for alight fixture.
Old 01-03-2014, 01:23 PM   #3
Thanks Joe!
I wasn't sure about the old brown paper looking thing in the outlet box at the top.
Old 01-03-2014, 01:25 PM   #4
Rewards Points: 1,294
50's vintage wiring was mostly cloth/paper covered "romex" style wire. some of this had a ground wire available in it, some did not. No problem either way as it is not required to be replaced. The insulation on the wires looks good.
danpik is offline   Reply With Quote
Old 01-03-2014, 01:31 PM   #5
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
I don't see anything throwing up a red flag right off hand. As long as you don't see anything bare or burnt, go for it.
Mort is offline   Reply With Quote
The Following User Says Thank You to Mort For This Useful Post:
Windows on Wash (03-19-2014)
Old 03-19-2014, 05:04 PM   #6
Rewards Points: 16
There is bare wire (black wire) showing under the yellow wire nut on the left. Bare wire is a no-no. You should redo that connection.
Ray103 is offline   Reply With Quote
Old 03-19-2014, 08:40 PM   #7
Rewards Points: 1,426
Hopefully he figured it out in the last 2 and a half months.
mikegp is offline   Reply With Quote
Old 03-26-2014, 09:13 AM   #8
beverlyLynch's Avatar
I never take risk in electrical matters. Always call off the professionals.
beverlyLynch is offline   Reply With Quote
Blank Plate Electrical Outlet - Doing it correctly? 7 VII 7 Electrical 19 07-28-2013 10:10 AM
Electrical outlet receptacle touching copper hydro pipe Jimmyswo Electrical 8 11-17-2012 11:27 AM
Installing Electrical Outlet in the place of an old Light Fixture Mikon8er Electrical 20 11-08-2011 10:23 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
HELP Installing Fault Interrupter Electrical Outlet!!!! pancho12 Electrical 5 06-15-2010 05:38 PM
