Old Dull Bricks?? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-29-2009, 07:06 AM   #1
Old dull bricks??
Looking for some ideas on the exterior brick on our house.Its an older house and the bricks look kinda dull.From what i've been reading painting them isn't the best way to go,I found this dyebrick.com that looks like it might keep the brick look and give it a new life.
Has anyone ever tried it,maybe a little feedback on it?
Picture from when we got our roof done, but maybe you can see the brick work we are working with.
photosbyvj is offline   Reply With Quote
Old 07-29-2009, 12:33 PM   #2
Roofing Contractor
Leftyho's Avatar
Hi,
Clean the brick.
Leftyho is offline   Reply With Quote
Old 07-29-2009, 04:00 PM   #3
Originally Posted by Leftyho View Post
Hi,
Clean the brick.
Got to love that short and to the point,lol.
Are you saying clean the brick and leave it,or clean it very good before using the dye?
Old 07-29-2009, 04:48 PM   #4
dyeee
clean it very good before using the dye.
Jazzy Brown
Jazzy Brown is offline   Reply With Quote
Old 07-29-2009, 05:19 PM   #5
Roofing Contractor
Leftyho's Avatar
Hi,
Clean the brick. It will look different. Sharper
If you did not like the color of the brick, why did you buy the house?
Motar dye will stick to anything. There is no turning back.
Old 07-29-2009, 10:46 PM   #6
Rewards Points: 5,336
This will probably be the worst idea you've ever had if you use this product. You will look back at this picture and yearn for the day you took it.
Try cleaning the brick, if that doesn't work, move. I think this scenario will work out better in the end.
Ron
Old 07-29-2009, 11:02 PM   #7
Concrete & Masonry
Rewards Points: 620
I personally don't think the brick look too bad, but I'm only looking at a very small section of the house, & YOU have to live with it everyday. The recommendation that I could give would be to get the wall wet. If you like the way it looks when it's wet, you could easily use a paver enhancer to bring more color out of the wall.
If you do decide to use some non-conventional brick stain, do youself a favor & get a bid or 2 on what it will cost to remove & replace the brick veneer. This will make you take a serious look at a "brick stain" & it's possible repercussions.
jomama45 is offline   Reply With Quote
Old 07-30-2009, 01:46 AM   #8
Thanks for all the input,guess i'm going to give it a good old scrub down with the pressure washer and hope it will do something for me.
Tried this before but maybe the new roof will give me a different look on it.
second floor on horizontally cored bricks Aussie Pete Building & Construction 2 01-13-2009 07:24 PM
Damp, Crumbling bricks & Blown Plaster crscrs Building & Construction 2 10-02-2008 05:20 PM
Problem with bricks in fireplace box pulling away from interior wall proofer Building & Construction 1 06-15-2008 07:54 AM
