Old Aluminum Window Replacement. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-08-2009, 11:17 PM   #1
Old aluminum window replacement.
I had two old aluminum window in my house replaced today with new retro-fitted vinyl windows. The window replacement person told me they had to re-trim around the windows as there was no original sheathing around them. They put trim around the windows and caulked around the upper and bottom edges of the trim. They just nailed the trim to the wood siding. I am worried that because there was no sheathing, there will be no way to really keep the weather from seeping through. Could they have done something else to ensure no moisture gets through?
nancwilt is offline   Reply With Quote
Old 09-10-2009, 06:02 AM   #2
Not sure what you mean. Many older homes do not have wood sheathing, but have something similar to drywall. It is designed for outer covering on a house, but does not hold nails very well. There are ways to insulate air gaps around windows, and insulating these is general practice when replacing windows. Although not all do it.
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Basement window replacement topher0524 Building & Construction 7 05-21-2009 02:59 PM
latest problem...window replacement gone_fishing Remodeling 10 02-11-2008 08:24 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
