Odor From Vents - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-02-2013, 11:30 AM   #1
KarenH's Avatar
Rewards Points: 79
Odor from vents
We are having a musty/moldy odor coming from the vents when we run the A/C. We sprayed Lysol into vents and this helps for about a day then odors return. Any suggestions would be appreciated.
KarenH is offline   Reply With Quote
Old 09-02-2013, 07:19 PM   #2
Rewards Points: 12,876
Basement, crawl space?
Checked for air leaks in the return lines and supply's?
Old 09-02-2013, 07:49 PM   #3
Rewards Points: 5,974
Could be the coils need cleaned. They make cleaner in rattle cans for this.
Old 09-02-2013, 07:59 PM   #4
KarenH's Avatar
Rewards Points: 79
Thank you so much! I will definitely try that.
Old 09-02-2013, 08:00 PM   #5
KarenH's Avatar
Rewards Points: 79
A crawl space. Haven't checked for leaks. Will try doing that. Thank you!
Have Gable/Soffit Vents Contractor Suggest Ridge Vents sallygump50 Roofing/Siding 3 05-11-2012 11:56 AM
Ridge vents, soffit vents, end gable vent confusion. joemill Roofing/Siding 4 04-01-2012 06:18 PM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 11:13 AM
Atic: Adding Intake and Exhaust Vents (Maybe Ridge) arcane Roofing/Siding 9 07-22-2010 07:20 PM
Ridge vents and roof vents jerry1967 Roofing/Siding 4 06-07-2010 06:40 PM
