Odd Basement Leak - From The Outside Walls - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 05-04-2007, 08:02 PM   #1
Odd basement leak - from the outside walls
We have a leak at the top wall of our basement that I think is related to poor drainage of a planter bed which allows water under our front steps. (Frustrating, because I thought I fixed this a year ago with new gutters just before we refinished the basement!)
The steps are solid concrete (I think) and have an porch/landing about 4' x 4' at the front door. There are no drain holes under the steps. Concrete was poured approximately 65 years ago...
Anyone know how to fix this, short of tearing out the steps?
DyerWolf is offline   Reply With Quote
Old 05-04-2007, 10:04 PM   #2
So Cal Electrician
Send a message via Yahoo to hbsparky
French Drain in the planter???
Well....Butter my butt and call me a biscuit!
hbsparky is offline   Reply With Quote
Old 05-05-2007, 08:51 AM   #3
concretemasonry's Avatar
Rewards Points: 2,608
Are you sure you completed the "fix" with gutters?
How long are your extensions? - 10' I hope, to an open discharge or a pop-up bubbler.
Is your surface drainage away from the house?
concretemasonry is online now   Reply With Quote
Old 05-08-2007, 06:17 AM   #4
How to fix cracks in basement walls
I had similar links in my basement walls, although the cracks were easily visible for me. You probably have water seeping thru a small crack between the steps and the foundation. I used Drylok Fast Plug, a quick-setting hydraulic cement that worked pretty well. Short of moving the steps, you could try a pastry bag or something similar to work the cement into the crack.
Roger
Webguy64 is offline   Reply With Quote
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 4 12-06-2012 08:26 AM
basement framing, walls parallel to joists DIY4EVER Building & Construction 8 06-06-2007 03:08 PM
Concrete basement wall leak CEE Building & Construction 3 05-26-2007 10:36 PM
Removing cement walls in basement / replacing with I beam bbockstanz Building & Construction 9 11-19-2006 06:31 AM
"floating" basement walls? greg s Carpentry 2 03-04-2005 07:56 PM
