Non-combustible Lid... - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 07:25 AM   #1
Dangerous
Non-combustible lid...
Our basement remodel includes an existing storage box that the previous owner made of brick, presumably at the same time they installed the wood stove and face the corner of the basement walls with brick...
The box is made of brick, is 51" x 18" x about 24" deep (makes a halfway decent bench, actually), and has a wooden lid that hinges up. The problem is that it's only about 12" away from the corner of the wood stove. It can't be moved.
The wooden lid concerns me. If I were to fabricate a new non-combustible lid for it... any ideas on what I could use for a material?
I assume the previous owner intended it to be used as wood storage for the stove.
Cerberus is offline   Reply With Quote
Old 01-17-2012, 07:32 AM   #2
DIY staff
Rewards Points: 7,174
If you could post a picture I believe you will get a lot of ideas---
Old 01-17-2012, 07:56 AM   #3
A Little Of Everything
Rewards Points: 1,364
Look closely at the lid. On the end near the stove, is there evidence of overheating? Bubbled paint? 12" away from the wood stove seems awfully close, but maybe there is no problem.
DrHicks is offline   Reply With Quote
Old 01-17-2012, 08:12 AM   #4
DIY staff
That is to close for me---12" from a wood burning stove---someone here will know the set back for combustibles---but I know it's more than 12"
Old 01-17-2012, 08:20 AM   #5
Right. I can't imagine why they built it that close. They must have never built much of a fire in that stove.
Old 01-17-2012, 08:26 AM   #6
DIY staff
That's what I thought----Mine glows red every now and then---
Old 01-17-2012, 08:32 AM   #7
Only red?
Back to the OP... I think he could put up some sort of heat shield, but I cannot see it being anything short of redneck. And I can think of several non-combustible materials he could use to build the lid, but none of them seem very feasible or attractive.
Old 01-17-2012, 08:53 AM   #8
Not so new
12penny's Avatar
Rewards Points: 520
Make the lid with Ipe. Class A fire rating, I think. Meaning it doesnt burn.
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
Cerberus (01-17-2012)
Old 01-17-2012, 09:17 AM   #9
DIY staff
That's an interesting thought!!!
Old 01-17-2012, 09:41 AM   #10
Dangerous
OK, what's that stuff...?
Checking my google-fu...
Old 01-17-2012, 09:43 AM   #11
DIY staff
IPE is a hard wood used for deck building----Nice looking---hard and heavy---water tolerant--easily found at local suppliers,
Old 01-17-2012, 09:49 AM   #12
Dangerous
Wow, good idea! Never heard of that stuff before now... Class A fire rating, I like it!
I'm going to look into that for sure.
Oh, my mistake, the distance is actually about 19" to the closest part, not 12" Sorry. I have a feeling it's still too close, though.
Old 01-17-2012, 10:07 AM   #13
DIY staff
Better safe---Do check on the fire rating---
Old 01-17-2012, 10:31 AM   #14
Rewards Points: 1,296
Not sure is Durock tile backer is fire proof or not.
If it is you could Laminate 3 or 4 layers to make a sort of "plywood" from it. Rout the corners with a carbide router. Seal it or paint it. Another option I thought of would be to have a metal lid formed but, I would imagine at 12" it would get real hot.
danpik is offline   Reply With Quote
Old 01-17-2012, 01:46 PM   #15
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,354
Ayuh,... Havin' lived around wood heat, most All my life,...
I think yer goin' Waayyy overboard, 'bout Nothin'.....
Bondo is online now   Reply With Quote
Combustible air high and low vents strix99 HVAC 10 05-22-2011 07:28 PM
New furnace combustible air vent question simonb HVAC 12 06-12-2009 07:04 PM
Combustible ----> Non-Combustible Wall cart0181 Building & Construction 25 05-29-2009 03:56 AM
New Range Hood - robbing combustible air??? drtbk4ever HVAC 2 05-26-2009 10:24 AM
Is drywall mud considered combustible? the carpenter Drywall & Plaster 2 01-24-2009 07:07 AM
