Noisy Pool Pump? - General DIY Discussions - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-15-2011, 06:41 AM   #31
could it be that its too old? - swimming pool filters
holgorhydrl is offline   Reply With Quote
The Following User Says Thank You to holgorhydrl For This Useful Post:
gigdad (06-19-2012)
Old 07-09-2011, 11:06 AM   #32
Hi! I have an above ground pool with a noisy pump.... seems to be coming from the filter housing rather than the motor. The pressure guage bounces like crazy! I have flushed the main hoses...filter cartridge is clear/clean... I am at a loss. I picked up a new gauge thinking it could be that, but it still bounced around between maybe 18 and 22 and now it is broken Any ideas? thanks!
kimmacc is offline   Reply With Quote
Old 08-14-2011, 07:48 AM   #33
Wethead's Avatar
Hi -
1) Check your water level, make sure you have an "air free" primed pump
2) Check if your impeller is wasted ( Loose and wobbly )
Let me know if you need more help
- Joseph
Need Help With Your Pump?►WeT HeaD Pump Repair ► Watch Me On YouTube: Pump Repair TV
Wethead is offline   Reply With Quote
Old 04-27-2012, 09:01 PM   #34
Wethead's Avatar
Originally Posted by pump View Post
Hi Wethead,
I have an onga ltp750 with a noisy bearing. I would appreciate instructions on how to replace seal and bearing in this pump.
Thanks Gerry
I just recently created a new video for bearing removal, so everyone could learn
Its on YouTube
If anyone has any questions, please do let me know, I am subscribed to this thread and I am glad to be of any help
Old 07-27-2013, 07:19 PM   #35
Angry
Pool FILTER is making a loud rattling noise
Just replaced hayward super pro pump or in ground DE pool. At the time my Hayward Perflex extended cycle filter was making a slight rattling noise. It's gotten really bad. Anyone out there able to help me. I'm posting a short video. Btw when I back washed a small white plastic piece with a hole in it came out (I think)
Please Help. Ty in advance
Saltyminnow is offline   Reply With Quote
Old 02-21-2014, 03:10 PM   #36
Wethead's Avatar
Hey Everyone!
Its 2014 and we now have 700+ videos online to help you with your pool and spa pump repairs,
check it out
http://www.youtube.com/user/ThePumpGuys
Love always
Joseph
Old 09-30-2014, 05:30 PM   #37
Rewards Points: 4
Pool bearing replacement
Originally Posted by Wethead View Post
Hi,
I am a "pool guru"
The motor bearing inside the motor have probably worn out.
Its best to get this repaired right away as worn bearings can create an extra load on the motor and could eventually burn the motor out.
If you have any questions, please feel free to ask me,
I can also explain to you how to replace the motor bearings,
Joseph
Hi Joseph,
My pool pump has been rattling for the past two weeks, have been told it could be something in impellor of baring worn out. How difficult is it to replace the bearings????i
jbrooks621 is offline   Reply With Quote
Old 09-30-2014, 05:37 PM   #38
Rewards Points: 4
Please send me info on changing bearings and impeller.
Old 10-01-2014, 08:26 AM   #39
air or bearings are shot
racing4funn is offline   Reply With Quote
Swimming Pool Converted To Fish Pond ghall79 General DIY Discussions 6 05-23-2008 11:11 AM
Just to confirm, no GFCI needed for hard wired pool pump..right?? Al the Diy guy Electrical 6 02-10-2008 12:28 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
noisy shower drain pump zoodemon Plumbing 5 10-04-2006 12:22 PM
GFI Breaker & pool pump mitchman333 Electrical 7 05-08-2006 05:32 PM
