-   -   No Water Flowing To Fridge (http://www.diychatroom.com/f2/no-water-flowing-fridge-14678/)
garyb123 12-22-2007 10:05 PM
I can usually figure stuff out, but this is really starting to bug me!
PROBLEM: water stopped flowing from the the valve in the wall, which connects to the 1/4 inch fridge supply line.
What I have done so far:
1) After turning off main (duh), I removed valve from house supply line, to check for blockage in valve. Valve is clean. Supply line is polyethylene, probably connected to a supply manifold.
2) Reinstalled valve.
3) Hoping it's a clogged line, I hooked up (with adapters & reducers) garden hose, to 1/4" tubing, to valve & backflushed water supply line several times. No help. Maybe not enough water pressure, with 1/4" tube.
4) My last idea is to remove valve & connect garden hose directly to
house supply line & back flush again. Will do this tommorrow. Assuming this doesn't work, does anyone have any ideas? I wonder though, if it is a clog, how would a 1/2" supply line become totally blocked? House is 4 years old, with municipal water supply (Las Vegas area). No other areas in house are affected.
Bondo 12-23-2007 09:31 AM
Ayuh,.........
Find Where it Comes from,+ See if you have a supply To it......
tribe_fan 12-23-2007 10:24 AM
Disconnect at the fridge put into a bucket- turn on valve -
This will tell you if the problem is in the fridge or supply.
If its in the fridge check the valve in there.
If the supply it is very unlikely a 1/2 inch pipe is clogged. It will likely be a valve, especially if it's a saddle type valve. Follow the poly to where if connects to the 1/2, and that will be your problem.
redline 12-23-2007 10:46 AM
Is there valve before thsis that someone may have turned off without realizing that it supplied water to the fridge?
garyb123 12-23-2007 05:40 PM
Before my initial post, I removed valve (ball type), from 1/2" line. It was clean.
End Grain 12-24-2007 12:28 AM
Does your refrigerator have an automatic sensor that shuts down the icemaker/water unit when the internal filter is clogged or in service for too long? You did say 4 years. Most refrigerators have a small electric pump in the rear base compartment that resides in-line between the icemaker and water supply line. It automatically starts and stops as the icemaker level arm falls and rises.
