No Sheer Strength In Garage Walls - General DIY Discussions - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-11-2011, 04:58 PM   #31
Framing Contractor
Rewards Points: 118
The osb or plywood needs to be gapped for expansion. Put the foam on after the osb if thats what your looking to do. I don't think the minimal increase in R value will be worth it.
sixeightten is offline   Reply With Quote
Old 05-11-2011, 05:45 PM   #32
I think your right, there is just such minimal sound and thermal gain off of 1" or so rigid insulation. And it would be pretty darn expensive.
How do I know the gap. Are there like spacers you can use when installing the osb, sort like those white cross shaped tile spacers? Or do I just make a piece of wood for a spacing jig?
Avadon is offline   Reply With Quote
Old 05-11-2011, 06:11 PM   #33
kwikfishron's Avatar
Rewards Points: 586
A spacing jig? You call a Blacksmith and have him make you one, and while your at it borrow his micrometer to check the thickness of your siding.
kwikfishron is offline   Reply With Quote
Old 05-11-2011, 06:27 PM   #34
okay so what is the spacing in regards to osb alignment to avoid buckling issues due to thermal expansion? Is it 1/16'th? an 1/8'th?
I am a blacksmith so....
Old 05-11-2011, 06:40 PM   #35
Rewards Points: 586
GBR already gave you the answer.
Old 05-11-2011, 06:58 PM   #36
I don't see anywhere he mentions spacing dimensions, unless it's buried in a link I haven't read yet. There are pages and pages on those of those links.
Old 05-11-2011, 07:07 PM   #37
There it was in that tiny 8 point font These recommended gaps of
1⁄8" must also be left around all openings. (I guess you couldn't have just told me that)
Old 05-11-2011, 07:11 PM   #38
Rewards Points: 586
Its right there, last link, last paragraph, second to the last sentence.
GBR took the time to supply you the links to answer most if not all of your questions, youd think you would be interested in the answers.
How thick is your siding?
Old 05-11-2011, 07:44 PM   #39
Instead of being a passive aggressive troll you could have just told me or not posted at all. I already said previously in the thread I don't have time to read through all the links right now. I'm at work. Sheesh. Grow up.
Old 05-11-2011, 09:38 PM   #40
Rewards Points: 410
Leave your siding alone.
OSB the interior so you can hang cabinets ect wherever you like and then
cover with 3/4 drywall for fire prevention.
Do the other steps as Ron posted , mineral wool insulation a big + for fire proofing.
Run your outlets just like in a factory in conduit along the walls.
No stranger to machining ......whatcha got ?
High Gear is offline   Reply With Quote
Insulate finished garage ceiling or condition garage? pasichnyk Building & Construction 19 12-06-2010 01:46 AM
Framing a garage loft narsh Building & Construction 3 05-26-2010 08:53 PM
garage walls bluefawn3 Building & Construction 1 05-20-2010 05:41 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 09:07 AM
Raising existing walls of a garage ok2rvtravel Remodeling 3 10-09-2007 11:45 AM
