Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 03-24-2010, 04:32 PM   #1
Question
No range of Motion for my garage door opener
I've replaced all the gears in my Craftsman garage door opener and the broken cable that caused the gears to be stripped. Now when I operate the opener with or without the door engaged the chain moved 3"-4", stops and then reverses itself. The safety sensors seem to be okay and the limit switch does not make contact. I'd appreciate any ideas on what to check next...
Kevin100
Kevin100 is offline   Reply With Quote
Old 03-24-2010, 08:15 PM   #2
It would help if you mentioned the model # of the unit, how old it was and if it had the electric eyes.
Ron
Old 03-24-2010, 09:46 PM   #3
It's a Craftsman 139.53973SRT 1/2 horsepower. It's about 10 years old but as I said I have just replaced all of the gears.
It does have the safety sensors but they are both solidly lit.
Thanks.
Old 03-24-2010, 10:25 PM   #4
firehawkmph's Avatar
Kevin,
If both eyes are lit solid, about the only other thing to check is the opening and closing force adjustments. Turn them all the way up and see if the operator will travel back and forth like it's supposed to. If the clutch adjustments are set too light, it will do what yours is doing. If that doesn't do it, I would replace the opener. If you got 10 years out of a newer sears, you did pretty good. Even though they are made by Liftmaster for sears, they are not specced the same. I don't usually recommend even replacing the plastic gears. About the time they go, it's about time to replace it.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-25-2010, 08:34 PM   #5
Mike,
Thanks for the advice. In retrospec I should have asked before replacing the gears although I've done that on my other bay about 4 years ago and it still works fine. I'll do as you suggest first checking the clutch adjustments and then replacing.
Thanks again.
Best regards,
Kevin
Old 03-26-2010, 10:39 AM   #6
Household Handyman
When changing a new gear care should be taken to assure the relationship between the driveshaft (the gear attaches to) and the "full open/full close" adjustments are not disturbed. This relationship can be re-established with a few adjustments. You didn't state which direction the chain is moving when it stops. IF the chain is moving as to open the door, when it stops this may be meeting the "full open" adjustment. Then if it moves only 3"-4" and stops the unit may be meeting the "full close" adjustment which may have gotten out of adjustment. Try removing the chain also to take it out of the equation, it may be binding on something. You state that you have another unit of this type. Carefully watch the gear on the good unit to determine the revolutions, then compare with the faulty unit. This will tell you if the faulty unit is turning enough revs or the stops may need to be adjusted. David
Motion Activated Light for Attached Garage jamiedolan Project Showcase 6 07-01-2010 01:52 PM
motion switch for garage High Gear Electrical 4 02-19-2010 09:21 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
duct a range hood into garage? jimb317 General Discussion 8 01-30-2008 08:41 PM
