No Flood Drain In My Basement - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-16-2014, 04:00 PM   #1
Question
No flood drain in my basement
Hello I just purchased my first house in September and I noticed that my basement does not have any sort of flood drain near the water tank or anywhere for that matter. I also looked over the house inspection forms too confirm that there isn't one. I'm looking to finish up the basement this summer with new flooring, drywall ext, but I'm not sure what I should do without having a drain in the basement. My main concern is that after I do finish the basement what if I have a flood, ill be hooped!. Is there anyone with the same issue or perhaps know of anything that I can do? P.s The boiler and furnace are both in a separate room in the corner of the basement. Thanks
Lysterfiend is offline   Reply With Quote
Old 01-19-2014, 10:22 AM   #2
If you do not want to install a floor drain, you could always install a sump-pump.
JonM is offline   Reply With Quote
Old 01-19-2014, 01:18 PM   #3
Rewards Points: 77
Really need to take into account some details to decide what to do. A drain system would be nice but very expensive to install. A sump well and pump is relatively cheap and provides some protection from appliance and plumbing leaks. I am assuming the water table is far below the basement floor? Any evidence of water penetration in the past? Cracks in the floor or walls?
Your bigger decision is about how to finish the surfaces. You need to determine the amount of moisture in the walls and floor before you just put something over them. A cement floor that seems dry can become saturated with water if you seal it up.
chiraldude is offline   Reply With Quote
tapping into basement tub drain muellertr Plumbing 11 02-07-2013 01:38 PM
Basement floor drain backup mimi123456 Plumbing 6 09-28-2012 11:02 AM
Old Basement Sink Drain - Clay? maybere Plumbing 7 09-27-2011 11:49 AM
Basement vapor barrier over mirror drain eubarch Plumbing 0 09-27-2011 09:57 AM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
