Nicotine Stained Vertical Blinds - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-01-2011, 10:16 PM   #1
nicotine stained vertical blinds
Hello!
I am new to this forum.
I am just wondering how to get the nicotine stain off of white vertical blinds that have been stained yellow from a smoker smoking in the same room as the blinds.
Thank you!
cockfighter is offline   Reply With Quote
Old 07-02-2011, 04:48 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 628
Originally Posted by cockfighter View Post
Hello!
Thank you!
Good luck, I hope you get an answer.
Old 07-02-2011, 12:48 PM   #3
Tizzer's Avatar
Rewards Points: 470
Tried bleach soaking in the bath tub or use the garden hose?
Tizzer is offline   Reply With Quote
Old 07-02-2011, 01:37 PM   #4
@Tizzer thanks I will try that!
Old 07-02-2011, 05:42 PM   #5
General Contractor
Mr Clean eraser sponges......typically I don't like those things but was quite amazed how well they worked for this very problem.
dsconstructs is offline   Reply With Quote
Old 07-03-2011, 08:58 PM   #6
@dconstructs
I tried your suggestion and it seemed to work really well. I could not completely tell because I think the blinds were actually not white originally but beige because I compared them to some other blinds in a room where there was no smoking and they looked almost the same after using the eraser.
Old 07-04-2011, 12:41 AM   #7
General Contractor
Sounds like they were alabaster, more common than white. Glad it worked for you,
Old 07-04-2011, 07:19 AM   #8
Too Short? Cut it Again!
Every smoker needing another reason to quit--at least indoors and around other people who may or may not themselves---should do a paint prep of a smoked in space. All that gunk is in the fabrics people sit on and wear. And frankly in their lungs. I cannot think of a better example of second hand smoke. After one job, with an entire family (including the baby of the teen--I guessed) having smoked continuously, I had nightmares of this orange/brown gunked up cleaning fluid dripping on me at night.
For complete paint prep of lots of houses and especially those of smokers? I got in the habit of calling ServiceMaster or other local cleaning companies with an army of people that would do walls, floors and ceilings spotless and ready for primer and paint. I asked for the appropriate fire damage team when doing a smoker house. It was cheaper than clients paying me to do the prep.
Still had to prime it with horrible smelling but effective primers and treat raw rood in basement with enzymes to get rid of the leftover odor before painting.
Anyhow, sounds like the Mr. Clean things worked for the blinds. I have had reasonable success getting discoloration out of blinds soaking in oxy clean. It worked well on vinyl window screens too although I usually turned to Purple Clean or something from the auto parts store to carve the orange tar and gunk loose. Or I would pressure wash at low pressure with an industrial cleaner.
Old 03-09-2012, 09:14 AM   #9
This is in response to your inquiry back in 07 about cleaning verticle blinds: if they aren't fabric covered, try 'Scrubbing Bubbles', the bath cleaner. I used this product on vinyl horizontal mini-blinds. I removed them, draped over my deck railing, fully extended, then sprayed with Scrubbing Bubbles. Immediately the foaming bath cleanser started doing 'it's stuff'! They became pristine white before your eyes! It even cleaned the nylon cords, etc! I used a garden hose to wash them off and allowed air dry outside then re-hung. They looked just like they did when new!
KimKS is offline   Reply With Quote
Window treatment options? bokeh Interior Decorating 15 05-20-2017 10:04 PM
Need Advice For Fun Project - liberating stained glass window jackson33 Building & Construction 9 03-08-2011 04:09 PM
adapting header from vertical blinds to drapes MARTENMAVEN Interior Decorating 0 10-12-2009 10:27 AM
Vertical wooden blinds DangerMouse Project Showcase 30 06-18-2009 02:11 AM
