Nicotine Stain Removal, How To? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 12-18-2007, 10:12 AM   #1
Landscape contractor
nicotine stain removal, how to?
I've got some nice maple cabinets in my kitchen that I'm trying to clean up but they are filthy with nicotine stains/grease combo. I have tried everything I can think of to clean them and nothing is really working that well. Does anyone have any suggestions?
timber is offline   Reply With Quote
Old 12-18-2007, 11:00 AM   #2
My wife swears by Thunder Blast and/or White Lightning, both work the same. They work great on nicotine but I would try on a small section of the cabinet first to see how they react. Not sure if she has ever used them on the cabinets in our house, but she probably has. You can usually find these at the "Dollar" type stores and at Lowes too I think.
cjett is offline   Reply With Quote
Old 12-18-2007, 11:02 AM   #3
Oldguy
Rehabber's Avatar
Try 'Purple Power' available at Wal Mart in the automotive section. mix it with equal parts of water. IT MAY DULL THE FINISH.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 12-18-2007, 03:56 PM   #4
I'll probably try both if I can find them. I think I've heard of purple power. If any of these do dull the finish, should I just apply a new clear coat?
Old 12-21-2007, 12:38 AM   #5
http://thehardwarecity.com/thc/index.html?sku=6319156
has worked for me.
gofrugal is offline   Reply With Quote
Old 12-21-2007, 09:24 AM   #6
jms
nicotine removal
equal parts of ammonia and water. Spray it on or sponge it on. let it soak for
30 seconds or so then wipe of with same solution.
Have a nice day.
jeff
jms is offline   Reply With Quote
Old 12-21-2007, 05:06 PM   #7
Tired, Cold, and Damp
slickshift's Avatar
Clean them as best you can
Don't worry about affecting the gloss, it's doomed anyway
Seal what's left with B-I-N white pigmented shellac
Re-paint with a quality alkyd or waterborne enamel
slickshift is offline   Reply With Quote
Old 12-22-2007, 03:29 PM   #8
Thanks for all the imput, I'm not looking forward to this! slickshift, I want to keep the stained finish that they have,so will just any shellac do?
Old 12-22-2007, 05:07 PM   #9
slickshift's Avatar
Originally Posted by timber View Post
...I want to keep the stained finish that they have...
That will be a difficult undertaking
Depending on how bad the staining is, I wouldn't take the job...at any price
It would be deceiving the customer that there is a good chance of this happening
If it's bad enough, there's not any chance at all
That being said, it's hard to say from here how bad it is
It's possible that one (or a combo) of the cleaning methods may remove the film if it's not too bad
In that case, if you can remove the film/stains, then simply use a few coats of oil poly to bring back the shine (which will be removed during the cleaning process)
It will be a "see what ya got" type deal...there's no way to know from here if you will have enough finish left and enough nic stain removed to do this
If it's gone too far, then use the pigmented shellac as a sealer, and paint the cabinets with a premium enamel (oil or waterborne)
That would be (or was) my first suggestion
That's a "for sure" thing
Old 12-23-2007, 08:21 PM   #10
I got you, I got confused when you said paint, Thinking you ment painting them with a color. I think they are already pretty dull from all the cleaning we've already tried. Thanks for the help!
Old 06-22-2009, 10:40 AM   #11
Thanks|
I definitely need to try that. Thanks
johnstevens is offline   Reply With Quote
Old 08-04-2012, 05:20 PM   #12
I have an old refrigerator and it is covered in nicotine. I believe it is plastic coating on it. How do I get rid of The brown nicotine coating?
Ozarkwoman is offline   Reply With Quote
Old 08-05-2012, 12:09 AM   #13
Too Short? Cut it Again!
This is an old thread but nothing has changed. Smoker residue is a pain to deal with.
I too have had good luck with Purple Power from the auto store. Simple Green is not bad.
Some posting to this same topic elsewhere said they had good luck with plastics and vinyls using magic eraser kitchen sponge things.
If the frig is stained so badly and the outer material is vinyl or plastic you may not be able to get all the stain.
You should differently do a search to see if you can find other posts.
Old 08-05-2012, 06:12 PM   #14
Thx I will try these things. Forgot about those eraser things. That's next try.
Old 08-18-2012, 09:15 PM   #15
Household ammonia. Nothing better. My wife found a mirror she liked that was a light brown but smelled of smoke. Someone told her about this and it was as simple as wipe on and wipe off. The mirror is now an off-white after cleaning.
remoder is offline   Reply With Quote
The Following User Says Thank You to remoder For This Useful Post:
Ozarkwoman (08-18-2012)
Problem - Polyurethane bleaches out Stain Color on Maple Table GhanaBhuti Painting 9 09-05-2011 11:50 AM
Paint or stain for shingled house? skwpt Painting 6 09-19-2007 07:41 AM
Carpet stain removal -help kiwibird Flooring 4 03-08-2007 11:09 AM
