Nicotine In Bathroom. - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-03-2013, 09:08 PM   #1
Nicotine in bathroom.
Hi Everyone!
Just moved into a friends home and looking for something to remove nicotine stains from a bathtub. It's actually everywhere in the bathroom, but the bathtub bothers me the most. Any suggestions?
Sisterearth is offline   Reply With Quote
Old 08-03-2013, 09:14 PM   #2
I'm wondering how that even happens. Anyway, get out the scrubber
creeper is offline   Reply With Quote
Old 08-03-2013, 09:58 PM   #3
Been there done it.
I've tried everything I can think of. Bleach, Comet, peroxide, baking soda, vinegar. Nothing seems to be working. I think I'll try the Zeps product next, it worked really well for his toilet....which was also a nightmare!
Old 08-03-2013, 09:59 PM   #4
Too Short? Cut it Again!
Nicotine itself is rather transparent so how it coated a bathtub baffles me. I see you are first time poster though so wonder if you are a troll?
The tars in cigarettes could stain a bathroom wall but I don't see how they could stain a tub unless this place you are living in has not been cleaned in like 100 years.
If so, and the place is so filthy. Find a new friend to crash with.
Old 08-03-2013, 10:26 PM   #5
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 4,652
^^^^ Me neither.... If it's a non-porous surface, (like a bathtub), it just wipes off with virtually any cleaner. (Porous is different)
MTN REMODEL LLC is offline   Reply With Quote
Old 08-04-2013, 06:20 AM   #6
DIY staff
Rewards Points: 7,174
I rather doubt that the tub stains are caused by nicotine---
Most likely you have rust/lime staining---try CLR and see if that helps---
Old 08-04-2013, 06:43 AM   #7
Rewards Points: 13,300
Notice brown stains also inside the toilet tank and running down the insides of the bowl?
Does the house have old steel pipes?
Had the water tested to see if there to much iron in the water and you may need a water softener?
The safest, cheapest, nicest smelling way to remove nicotine stains I've used is one of the orange cleaners. Any Dollar store will have it.
It cleans so good you need to start at the bottom of the wall and work your way up to reduce streaks.
oh'mike (08-04-2013)
Old 08-04-2013, 08:47 AM   #8
Bill Kearney
Rewards Points: 1,174
BE CAREFUL ABOUT MIXING CLEANERS. You can KILL yourself if you screw around mixing different kinds. Bleach and ammonia being the two biggest risks. You need to make certain to fully rinse away ANY traces of previous cleaners before trying something else. Otherwise the cleaners might mix and release poisonous gas, toxic enough to kill. Might be a bit late now, as clearly you didn't kill yourself, but be warned to be VERY careful about this in the future.
wkearney99 is offline   Reply With Quote
Old 08-04-2013, 03:20 PM   #9
Rewards Points: 81
I onced used Denatured alcohol to clean a fuse box panel that was just covered in 30 years of smoking residue. After just a couple squirts, the brown sludge was running off so fast that it stained the sheetrock below before I could contain the mess.
one cut is offline   Reply With Quote
Old 08-04-2013, 04:10 PM   #10
Rewards Points: 5,974
Really don't think you are dealing with nicotine.
Old 08-04-2013, 08:10 PM   #11
One spark when using Denatured alcohol and it can explode of at least burst into flames.
creeper (08-04-2013)
Old 08-05-2013, 03:20 AM   #12
paper hanger and painter
chrisn's Avatar
Rewards Points: 236
no way
Old 08-05-2013, 12:26 PM   #13
Ok, Ok, I get it! You guys want to know where I'm from! So it's posted. And no, why on earth would I want to troll a DIY fourm???!!! Just looking for some help to clean nicotine out of a bathroom! geez!
Old 08-05-2013, 01:17 PM   #14
Rewards Points: 274
Some kind gel type bleach/cleaner are also helpful, if we apply them on the stain and leave for 5 minutes then smoothly rub that stain. Available any good store.
alexjoe is offline   Reply With Quote
The Following User Says Thank You to alexjoe For This Useful Post:
Sisterearth (08-05-2013)
Old 08-05-2013, 01:26 PM   #15
Rewards Points: 1,294
Is the tub a steel/cast one with porcelean, a fiberglass ar a vacume formed PVC one. I had one of the PVC ones and the plastic changed color as it aged. The color change was not reversible. If it is fiberglass, I would try a polishing compound to see if it will bring back the color. This also can be done on steel/cast as well
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
Columbus Ohio Basement Full Bathroom -Post-Construction Compliance Hermi14 Plumbing 5 03-12-2013 08:11 PM
Rewiring Bathroom & Den heyjoe91 Electrical 4 02-21-2013 05:22 PM
Exhaust Vents - Bathroom and Stove trophywalleye HVAC 0 03-19-2011 11:14 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 10:47 PM
