NiCd Charging Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-25-2008, 01:36 PM   #1
NiCd charging question
so my understanding with NiCd batteries is they should be used until they they are obviously low, but not completely dead, and that if you are not using them, they should be re-charged about once a month to keep them working well. My question is, do I need to ensure that the battery is pretty much dead at the end of a month before charging it? Trying to avoid memory issues with some new batteries that I have. thanks
larsonec is offline   Reply With Quote
Old 06-26-2008, 01:41 PM   #2
Rewards Points: 18
hello, yes NiCad batteries should be run to full dead before you recharge them to avoid the memory problem. It is OK to recharge them sometimes before they are dead, but not as normal practice.
These batteries in power tools don't last very long. I've replaced mine with new NiMH cells, take apart the battery pack and remove the tabs and resolder them to the NiMH cells in the same config, the charger works the same. They last longer than the NiCad and don't have the memory issue.
Jack
nimblemotors is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
New service Question Onytay Electrical 1 10-24-2007 05:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
