Newbie Question - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-15-2008, 01:35 PM   #1
newbie question
Hi everyone,
I need to move this a liitle to the right.
Can I just fill the hole with toothpicks and redrill over this area?
Thank you!
gobo is offline   Reply With Quote
Old 01-15-2008, 01:41 PM   #2
Building and plumbing
USP45's Avatar
Rewards Points: 150
Should work, I use a splinter of wood also when I mess up, best to place some glue into the hole and onto the toothpick(s)
USP45 is offline   Reply With Quote
Old 01-15-2008, 02:56 PM   #3
or you can
get a small piece of dowel and drill a hole just slightly smaller than the dowel. Put some wood glue into the hole and on the piece of dowel, drive the dowel into the hole and cut if off flush. This works when the other trick doesn't.
Jersey Bob is offline   Reply With Quote
Newbie Insulation Question: Cathedral Ceiling Battman328 Building & Construction 5 01-24-2008 06:37 PM
Newbie question about crack in PVC joint LinusInPW Plumbing 8 11-17-2007 12:25 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
Newbie Question bjp Introductions 2 10-09-2006 03:37 AM
