Newbie Homeowner Seeks Advice - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-07-2011, 07:06 PM   #16
Retired from the grind
Rewards Points: 6,652
That would work. Plus you can reuse it for other various items, such as marking how catv/telco/ethernet runs, hvac, plumbing, electric, for your record, if any changes are made.
Just put the words "Water, Gas, Electric" in the places that the shut offs are. Also helps for anyone that may be house-sitting for you also, so they know that it is on the electric panel. Just place a clear sheet protector on the outside of the breaker panel, and slip this sheet in there, with the numbers for utility emergency numbers, a couple of plumbers, hvac, electrician in order of who first to try, then so on.
I tend to shop around for hvac companies every couple of years, but have a good roofer that does some other stuff for me structurally if I need, along with his father, and a guy that does a/c & my plumbing. Anything else I play Russian roulette when needed.
DIY Advice Seeker - late 1970 seventies knockdown texture onegative Drywall & Plaster 1 04-22-2010 08:40 AM
Need advice on deck flashing, water stain Durt Ferguson General DIY Discussions 4 04-20-2010 05:09 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 09:07 AM
Newbie here and need advice... fp1 Painting 21 01-29-2007 11:39 AM
another newbie seeking advice nitrozorro Building & Construction 2 08-14-2006 09:03 PM
