New Windows - Problem - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-22-2010, 07:31 PM   #1
new windows - problem
I have new windows house was built in 2000. Ive noticed the bottom park of the windows if u push it up it should stay up several windows wont stay up they fall back down if you let them go. Not that i need to put windows now ill fix them in the spring or if we have a warm day. thanks
cdundon4va is offline   Reply With Quote
Old 01-22-2010, 09:02 PM   #2
Remodeler
adpanko's Avatar
Rewards Points: 150
the sashes probably became disconnected from one or both of the tensions springs that make them stay up.
adpanko is offline   Reply With Quote
Old 01-23-2010, 06:56 AM   #3
Yes, it sounds like the sashes came out of the recoil mechanisms. You need to remove the sash and use a screw driver to reposition the recoils and then reinstall the sashes. You notice that the bottom of the sashes have a slotted piece of metal. That rides inside of the mechanism. When you rotate the window into the room that slotted piece of metal rotates the mechanism and locks it into place. If you don't slide the sashes back into those slotted mechanisms, the window won't operate. Sometimes people don't know and force the windows, eventually breaking them.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 01-23-2010, 07:05 AM   #4
Tom Struble's Avatar
Rewards Points: 2,002
usually happens when you don't lift the sash a few inches before you tilt them to clean
Tom Struble is offline   Reply With Quote
Old 01-28-2010, 12:03 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
They are called balances. As has been mentioned they probably slipped out of the keepers, although I've seen some cheaper models where the balances that were installed by the factory were insufficient to fully support the sash. Since this is happening on several it could be a possibility.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 01-28-2010, 04:07 PM   #6
Rewards Points: 5,336
This isn't something you might want to do this time of the year but, take out one of the offending sashes and look at it. It depends on how versed you are at operating one of these. See if something is disconnected or broken. Parts are available to replace broken balances.
Ron
Replacing Windows? Kyle Remodeling 13 12-17-2009 07:03 PM
Typical Cost to Install Anderson 400 Windows jombres General DIY Discussions 1 10-16-2009 09:57 PM
Co. installing my impact windows measured all wrong. Now they want to "rig" them in. heydade General DIY Discussions 45 10-10-2009 03:44 PM
Replacing aluminum frame windows gallasm Remodeling 2 01-05-2009 10:03 AM
How to caulk windows the RIGHT WAY? fritzycat1 Painting 3 09-10-2007 06:32 PM
