New Window Install Into Old Broke Glass/rock Stucco Exterior - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-11-2011, 01:04 PM   #1
new window install into old broke glass/rock stucco exterior
I am installing new construction windows into my 47year old home. The homes exterior consists of a rough broken glass rock stucco that was coverd with elastomaric 14 +years ago. I want to cut the stucco out around the window, remove old window, install new and frame new window with wood, butting up against the stucco. My conscern is making it water tight . Any one out there done anything like this?
falcon47 is offline   Reply With Quote
Old 06-11-2011, 08:02 PM   #2
Rewards Points: 6,652
4" cutting wheel, or a Oscillating cutter will do the job.
The Following User Says Thank You to gregzoll For This Useful Post:
falcon47 (06-12-2011)
Old 06-12-2011, 12:42 AM   #3
Registered User
Rewards Points: 5,236
You need to paper and seal the windows for a quality job, leak free; http://docs.google.com/viewer?a=v&q=...WrZBbBZoIUXgxw
The papering will be similar, not the drip cap or vented walls: http://www.mtcc1170.com/images/BCRainScreen.pdf
http://books.google.com/books?id=0dz...age&q=&f=false
http://books.google.com/books?id=mFT...age&q=&f=false
Different stucco, similar flashing details: http://docs.google.com/viewer?a=v&q=...X1IjstvXQPNoxA
Gary
Old 06-12-2011, 11:07 AM   #4
Hi Gary thankyou for the information.
Old 06-12-2011, 11:29 PM   #5
Registered User
You are welcome! Stucco is a specialized trade though if careful and read up..........Hope it works out.
Gary
window install on t1-11 racebum Building & Construction 3 07-19-2010 08:17 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 06:00 PM
New exterior french door install in a stucco wall lightninrodman Building & Construction 2 06-30-2007 12:08 PM
couple of q's on stucco exterior joeyboy Building & Construction 7 05-19-2007 11:04 AM
Window jamb helpless handyman Carpentry 11 08-03-2006 01:45 PM
