New Room/closet - Carpet Or Cabinets First? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-11-2013, 11:33 AM   #1
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
New room/closet - carpet or cabinets first?
I have a newly constructed room/walk-in-closet in my basement. It is going to be carpeted with the rest of the finished area - in the future. I plan on installing a 6' run of base cabinetry, with a countertop, and wall cabinets above it.
My question is - when should I install the base cabinets? Should I install them before the carpet is installed and have the carpet run up against them, or wait and install them after carpet is [eventually] installed? I think the former is correct, but I don't want to have to remove them and re-install them because I jumped the gun.
Thanks!
hyunelan2 is offline   Reply With Quote
Old 01-11-2013, 11:40 AM   #2
Rewards Points: 578
i dont know what's "proper" but it seems to me that you would do it before. If you do it after the carpet is down, and something happens and you have to replace the carpet, you would have to uninstall all of the cabinets in order to do that.
TrailerParadise is offline   Reply With Quote
Old 01-11-2013, 11:46 AM   #3
hyunelan2's Avatar
Rewards Points: 692
I agree, that would make the most sense. I guess I've never installed (or had) base cabinets in a room with carpet. It's always been a hard surface (wood/tile/vinyl) and the cabinets were installed on top of the surface. Not sure if that's proper or not, but the way my last 2 houses were done.
Old 01-11-2013, 12:00 PM   #4
Rewards Points: 578
hmm im not sure but i dont think thats the way it should be. In my kitchen i intend to install base cabinets first and run the wood up to them, because it will be easier to replace a damaged spot. I dont honestly see how you would install them over carpet. Seems to me that they would be nearly impossible to level, not having a hard surface beneath.
Old 01-11-2013, 12:15 PM   #5
hyunelan2's Avatar
Rewards Points: 692
True. Common sense would seem to dictate to install the cabinets first. Thanks for making me think with common sense for a second here.
Cabinets To Go! CapnHawk Kitchen & Bath Remodeling 64 03-29-2017 02:14 PM
Carpet Flooding and Replacement airjay81 Flooring 1 05-08-2012 12:00 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
