New Pool Leak - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-30-2010, 09:32 AM   #1
New pool leak
Hi all, new guy here. Recently, last weekend, I replaced my pool light fixture. Since then the pool has been leaking. I went back into the niche and sealed the conduit hole, with putty, for a temporary fix to see if that was the reason for the leak. It wasn’t. I filled the pool to a marked level and over night, no motor running, the water level dropped about an inch. I don’t see how the water could drop so fast even if the putty wasn’t doing the trick. I also let the water drop lower than the skimmer intake to verify that the leak wasn’t from the skimmer.
All I did was replace the lighting fixture. I cut the cable from the old fixture, spliced the new fixture cable to it and pulled it through the conduit. Then i screwed the fixture in place. It wasn’t a perfect fit, but; it is a wet housing and the old fixture didn’t have a gasket and the bottom screw was missing so it wasn’t a ”perfect” fit either. Any ideas?
thanks in advance,
britt
b.lowry is offline   Reply With Quote
Old 09-30-2010, 01:50 PM   #2
No Hacks Allowed!
I have a concern about your electrical conduit seal behind the pool light.
What type of light fixture/conduit seal did you use to STOP water ingression into your conduit where the electrical conductors and the wire splices are located?
I would be much more concerned with keeping water away from the pool light conductors after your repair than a dropping water level at this point!
NoHax is offline   Reply With Quote
Old 09-30-2010, 02:34 PM   #3
I only spliced the wires to pull the new cable to the J-box. Then I disconnected the splice and hooked the wires to the power source.
swimming pool light leak... Bet General DIY Discussions 17 09-18-2012 12:13 PM
Pool Cement Apron Issue ajdevoll Building & Construction 7 09-08-2010 09:57 PM
Swimming Pool subpanel tedpoppke Electrical 3 08-24-2010 08:59 AM
inground swimming pool pipes leak when pump running.. rgebhard Plumbing 4 06-26-2010 06:35 PM
Swimming pool light leak chrishim General DIY Discussions 2 10-21-2009 09:52 PM
