New Low Power Lines Under Sidewalk - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-06-2013, 08:38 AM   #1
Rewards Points: 80
New Low Power lines under sidewalk
Other than water jetting, does anyone have a suggestion or tip on how I can trench under sidewalk for new line?
Water will make things very messy quickly! Can I cap a piece of conduit and hammer it under?
Thoughts?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 11-06-2013, 08:23 PM   #2
Rewards Points: 960
Just dig a hole on each side and use a drill bit and extensions to drill a tunnel underneath. A cable install guy did this once for me.
cleveman is offline   Reply With Quote
The Following User Says Thank You to cleveman For This Useful Post:
digitalplumber (11-06-2013)
Old 11-08-2013, 11:45 AM   #3
Bill Kearney
Rewards Points: 1,174
Verizon subcontractors just used a long metal rod. Hammered it under. Assumes you've got a pole that'll survive being hammered through dirt. I don't think conduit would.
I used a piece of PVC and put a hose jet nozzle on the business end and a regular female hose coupling on the other. Used it as a water jet to blast through to the other side. Sure, it was a bit messy, but it's just mud and it dried out just fine. The important thing to remember is not to undermine the pavement too much. You only want a hole big enough for your conduit. And you'd probably want to avoid doing it where there's going to be a seam above.
wkearney99 is offline   Reply With Quote
Old 11-08-2013, 05:39 PM   #4
Rewards Points: 80
Thanks everyone!
Old 11-08-2013, 06:01 PM   #5
kwikfishron's Avatar
Rewards Points: 824
Just dig! No rentals or space age tools required!
Look, I'm already done!
kwikfishron is online now   Reply With Quote
Old 11-08-2013, 06:17 PM   #6
Rewards Points: 824
Originally Posted by digitalplumber View Post
Some of you have way too much free time!
I was serious. Dig a hole on each side and then use a crowbar or something and start poking and digging. You may get dirty but you'll get it done.
I've done this many times.
Old 11-08-2013, 06:20 PM   #7
Rewards Points: 80
Yes I know you were and thanks!
I will attempt the use of a round bar and sledge first. No water too messy!
Install new faucet with compression fittings to larger copper supply lines cwb124 Plumbing 7 02-27-2013 04:11 PM
Dishwasher Power Supply Captain.Sassy Electrical 14 09-14-2011 05:28 AM
Cracked, Sunken, Too high Sidewalk! fake50 Landscaping & Lawn Care 0 04-13-2010 01:01 PM
Sidewalk drainage issue! Bcoleman6 Building & Construction 1 07-07-2008 02:17 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 10:23 PM
