New Leach Bed Leaking Into Tank - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 10:47 AM   #1
New leach bed leaking into tank
Hi:
I created a gravity flow leach bed in my backyard last summer to replace the existing unsightly raised bed that is eating up a majority of the yard. I kept the raised bed in place until I was sure the new bed functioned properly. With a recent thaw and large amount of rain, the new bed started backflowing back into the pump chamber, so I started using the raised bed again. Here's my question: Could the backflow issue be caused by 1. water flowing down from the raised bed 2. by poor landscaping ( I noticed that the earth used to backfill the new tile-bed runs has compacted, created ruts where the runs are, leaving water to pool there).
FYI, the soil is clay. I created three, 70 foot runs of perforated pipe, with used plenty of "clean" grave as backfill for about 18 inches of coverage under and over the pipes.
Houlio is offline   Reply With Quote
Old 03-07-2011, 10:53 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,602
Ayuh,... If the leech field is saturated, it'll do what it's doing til the water table goes back down....
Mine does it most every year, 'n corrects itself with time, 'n warmth...
Septic Tank not flowing into leach lines or drain field michaelschier Plumbing 19 09-01-2010 07:58 AM
Garage over Septic tank and Leach lines canyonbc Building & Construction 11 01-13-2010 10:48 PM
Leaking tank bolts splinters Plumbing 4 12-25-2009 06:04 PM
Pressure relief leaking and expansion tank full themow HVAC 1 11-25-2009 04:49 PM
Leaking from toilet tank? tripflex Plumbing 4 09-29-2009 11:29 AM
