New Hinges - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-14-2010, 09:59 AM   #1
Rewards Points: 27
New Hinges
I have 2 interior doors that I relaced the hinges on and the doors no longer close. Both doors now hit the jamb on the opposite edge. The shift was probably about an 1/8" or little more. (I used the same hinges on two other doors and they are fine.)
First question is what causes hinges to change the fit of a door? Visually they look the same.
Second, is there a way to manipulate the hinge to pull the door back like the original hinges or am I committed to shaving the edge of the door down?
diykc is offline   Reply With Quote
Old 02-14-2010, 10:30 AM   #2
Rewards Points: 5,336
If the hinges are thicker they will push the door towards the latch.How much of a gap is there between the door and frame on the hinge side. A simple solution would be to deepen the mortises if the gap is large enough.
If you shave the door, do it on the hinge side. The lock mechanism needs a certain setback that might not be kept if too much is removed from the latch side.
Ron
Old 02-14-2010, 10:44 AM   #3
some hinges come with a throw/curve in them. you may have these set in wrong try looking down the length of hinge to see if they can be reversed to pull door to jamb. are they the same width as those removed?
The older I get the better I was
Old 02-14-2010, 12:13 PM   #4
jlhaslip's Avatar
Rewards Points: 980
you may be able to 'bend' the jamb side of the hinge to get a better fit. Decreasing the 'throw' mentioned above.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Converting Overlay Hinges to European Hinges dennisd Carpentry 17 03-29-2010 05:51 PM
Blum hinges from 15 years ago?? MI-Roger Carpentry 14 02-23-2010 01:44 PM
Cabinet hinges don't fit... arghhhh!!! pisces7378 General DIY Discussions 7 12-25-2009 08:47 PM
Remove paint from hinges on cabinet debpie Painting 3 11-09-2009 01:09 AM
Cabinet Door Hinges Eric_ht Carpentry 6 11-24-2007 10:13 AM
