New Handleset In Older Door - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 06-19-2010, 01:38 PM   #1
Question
New handleset in older door
Looking to replace the locks in our house and one tricky issue is the front door. It's got an older one piece handleset on it with an 8 inch long assembly inside the door jam.
So I'm looking for a handleset that will fit exactly inside the existing cutout inside the door. It's exactly 8 inches high.
I had been looking at Schlage and Baldwin. Do you know of any handlesets from these brands that will fit my door?
Attaching a photo of the door & lock so you can see what I mean.
I had been looking at handlesets like this but I don't think they'll fit?
Baldwin Handlset
Schlage Handlset
thanks!
villain189 is offline   Reply With Quote
Old 06-19-2010, 01:54 PM   #2
fabrk8r
fabrk8r's Avatar
That is called a Mortise lockset. Most were very well built, much higher quality than locksets made currently.
When I had a problem with mine I took it apart, gave it a good cleaning, replaced a few small parts, lubricated it and put it back into service. Good as new.
I made a new faceplate out of a piece of heavy brass I had left over from another project because it was very worn. It had been rubbing on the strikeplate screws that the previous owner had let come loose. There are places which deal in parts for these older locksets if you search the web.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 06-19-2010, 03:01 PM   #3
I think you have in mind to replace the whole assembly with a new standard type lock. It is very possible to do, but requires a few tools I hope you have. Let me take you through it:
Remove the old handle and the entire old assembly by taking out the two screws on the door edge. You should be able to get it out easy enough. Now the fun part. I cut a pieve of 3/4" pine down until it just fits the hole where the assembly fit in. It doesn't have to be jam tight. Put glue on it before inserting and then pin it with an 18guage brad gun. Now prop the door on the hinge edge so you can work on it easily. I used a small router to route a 1/4" debt on the entire opening of the old assembly. Now cut a piece of pine 1/4" thick to fit the opening entirely. Glue it and brad it close to the ends. Stay away from the middle as you will have to drill it and route out for the new bolt.
Now use a template guide tyo cut a 2 3/8" hole for the new lockset. Also drill a 7/8" hole in the edge of the door that intersects the 2 3/8" hole. The new lockset usually comes with a template to mark the drill points. Insert the new bolt in the 7/8" hole and outline it with a pencil. Now route that area out to a depth equal to the plate on the bolt. Insert the bolt again & screw it in. Now put on the new handle and screw it together. You're done except for some light sanding and painting. (probably want to do this prior to putting the handle on.) If you have the tools the whole process will take about 1/2 hour. Fill the old lock hole with a small piece of wood and finish it off with wood filler. Sand it out and paint.
dadflynn is offline   Reply With Quote
Old 06-19-2010, 07:07 PM   #4
Thanks. Would it be easier to do what you said and install a modern lock if I wanted to go the replacement route?
Or if I were to buy a Baldwin Mortise to replace it with would it likely be an easy replacement? Or are the modern Mortise not the same dimensions as an older one? House was built in 1956, not sure when the lock dates from.
Example of Baldwin Mortise handlesets.
http://www.handlesets.com/index.cfm?...mortise%20lock
Locks spins and doesn't work very well so I'd like to replace it.
Old 06-21-2010, 10:40 AM   #5
Wow! Those prices are wild. I don't know the answer to your question, but you can find out by measuring your mortised piece, then calling Baldwin. You'll be able to get their number on the internet. Good luck.
Old 06-21-2010, 11:21 AM   #6
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Are you sure you need to replace the whole thing?
I have a similar one (from 1930) on my front door and the locksmith was able to just replace the cylinder & key when we bought the house.
CoconutPete is offline   Reply With Quote
Old 06-21-2010, 11:34 AM   #7
Thanks for the info. I think I'm going to go the recommended route and just have it repaired!!
On a sidenote there's a separate deadbolt I'm going to replace. Judging from that picture would you think Antique Brass would be the best finish to match the handleset?
thanks
Old 08-25-2010, 03:43 AM   #8
Another alternative to modernising older mortise locks, to take modern style entrance sets and the like, is to source a renovators plate.
There are multiple manufacturers, but one of the better know ones is Don-Jo.
globallocky is offline   Reply With Quote
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 03:19 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Entry Door---My Story----Advice Please rossmoor Building & Construction 3 02-29-2008 09:13 PM
