New Guy With A Question... - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-02-2009, 09:03 PM   #1
New guy with a question...
Hi -I'm Doug from El Paso, Tx - an amatuer handyman looking forward to picking up some useful info from experts.
We recently needed to hang some heavy-duty shelving in an office space and needed to get through the sheetrock, the gap behind the sheetrock (about 2 1/2 in.) and then into the cinder block (wasn't hollow). A series of 2x4's placed vertically was being attached to the interior wall and the total drilling depth was about 4 1/2 in. Attempts to pre-drill and then use lead anchors in the cinder block proved unsuccessful for us (amatuers). Another shopping run and we found 5 1/2 in. Tapcons (said to be the longest available.) To date, the fully loaded shelving is still in place. The question I have is: What could we have used if the needed drilling depth would have been greater? As it is, there was only about an inch or so of Tapcon biting in the pre-drilled hole, so we loaded in quite a few extra to ease our fears... if there exists some other fastener we would probably go back and load them in as well.
Thanks for listening... dneely
dneely is offline   Reply With Quote
Old 02-02-2009, 10:14 PM   #2
Old School
Willie T's Avatar
Butterfly toggle screws would be about the only other way to go that I can think if you cannot get to the back side of the wall. But if it wasn't hollow block, that wouldn't work. Red-heads don't work too well in block, period.
Willie T
Old 02-02-2009, 10:18 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,380
Ayuh,...
I would screw into the 2x4s to support the shelving,..
If I didn't think the 2x4 were firmly attached to the concrete wall,...
I might predrill,+ use a pile of those 5, 1/2" tapcons to Securely attach 'em....
Bondo is online now   Reply With Quote
Old 02-02-2009, 11:22 PM   #4
(the original)
Rewards Points: 756
That sheetrock has to be fastened to some kind of studs, probably steel if this is a commercial structure. You should have screwed the vertical 2x4s to the studs, or, if the spacing didn't work for your desired location, screw some 1x4s horizontally across the studs and screw the 2x4s to those. Tapcons are strong, but not designed to be holding a lot of weight hanging out in space like that. If the bottoms of your 2x4s are resting on the floor so they support the load instead of being part of the load I expect you'll probably be OK, though. If they don't reach the floor, I'd consider it an accident waiting to happen. Hope you're not in an earthquake prone area
ratherbefishin' is offline   Reply With Quote
Old 02-02-2009, 11:34 PM   #5
Rewards Points: 2,906
Dneely:
I agree with RatherBeFishing.
Think of it this way: If there were no strapping behind that drywall, how was it hung? In mid air? There had to be something to hang the drywall onto, and you should have found out where it was and fastened your 2X4's through the drywall to it. (or as previously suggested, fastened horizontal boards to the strapping through the drywall, and then fastened your 2X4's to those boards where convenient.)
Invest in a Zircon stud finder. You can buy them at any hardware store or home center. That tool would have allowed you to find any wooden strapping behind the drywall. I've never worked with steel studs, so I don't know if that tool can be used to find steel studs, but I suspect so.
If the wooden 2X4's aren't resting on the ground, then I agree it's an accident waiting to happen, and it won't take an earthquake to precipitate it. Some secretary standing on a chair and putting a foot on one shelf to get at the stapler on the top shelf would be enough to bring down the shelving.
Bashing my head against the walls in some of the internet's finest chat rooms.
Nestor_Kelebay is offline   Reply With Quote
Old 02-03-2009, 09:26 AM   #6
Old School
Willie T's Avatar
Ok, let's attack this from the opposite direction.
This is an office, right? Hopefully a hanging grid & ceiling tile ceiling? Probably steel joists overhead.
Steel bar joists make excellent hangers, especially right up near the wall. Can you get into the ceiling to see if there is some way you can hang those 2 x 4's off the bar joists (or any type of joists right up against the wall) where the few hundred pounds of load won't really effect much?
Willie T
Old 02-03-2009, 11:33 AM   #7
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 826
I didn't read anything about load on the shelving, manufacturer's model, etc. If I knew that, I could give some advice.
Aggie67 is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
New service Question Onytay Electrical 1 10-24-2007 05:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
