Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 12-16-2011, 08:55 PM   #1
New guy, with a new question. ceiling fans and drop ceilings?
There are 2 ways that I know of, neither of which I have personally done.
I need to install about a dozen ceiling fans into a suspended ceiling. The tiles are 24x48
Should I mount the box to the joists and drop a fan pole through the tile.
---OR---
Should I "hang" a box ( Arlington FBRS420SC-1 ) from the joist and mount the fan directly to it?
I like the idea of the Arlington box, any one do this before and have a preference over the 2 methods?
Here is the kicker, the roof slopes towards the rear of the building and I would have to account for the drop in height if I use the "pole" method. If I use the Arlington box then all fans would be uniform without much thought.
Please advise
TY
4gvn by Him is offline   Reply With Quote
Old 12-16-2011, 09:01 PM   #2
http://www.residential-landscape-lig...LLD8440WST.htm
Old 12-16-2011, 09:38 PM   #3
Thanks Joe, but $36 a pop? ouch
The ones I found were in the $24 range.
So are you saying you would mount a box down at the grid if given the choice?
Old 12-17-2011, 09:10 AM   #4
I have never installed a fan mount in a drop ceiling before, but I believe the Arlington FBRS420SC-1 or the Westinghouse 0107000 Saf-T-Grid would work just fine. As long as the load is carried back to the joists via cables or chains, it should work.
The Westinghouse bracket, as joecaption poined out, is available on Amazon for about the same price as the Arlington bracket.
I have installed a projector on a drop ceiling and it consisted of a plate that mounted in the grid over the tile, with aircraft cable to the joists supporting the load.
daveplot is offline   Reply With Quote
Old 12-18-2011, 10:59 PM   #5
My biggest concern is vibration over the long term.
Will the grid mounted boxes hold up well over the long haul?
I'd hate to slowly shake the grid apart if my fans aren't perfectly balanced.
Old 12-18-2011, 11:02 PM   #6
Electrical Contractor
As long as you install the correct braces, like the one listed above, you will be fine.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 12-18-2011, 11:27 PM   #7
Alright, thanks JB
Ceiling Fan Conversions BandC Electrical 4 03-20-2010 07:14 AM
Should a Homeowner get a permit for Fans Klawman Electrical 36 11-26-2009 03:31 PM
Ceiling Fan Advice rlynch HVAC 13 08-30-2009 07:37 PM
Ceiling Fan /w light wiring question beachbone Electrical 4 02-04-2009 11:42 PM
