New Grout And Caulking On Bathtub - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-08-2011, 08:45 PM   #1
New grout and caulking on bathtub
I will be applying new grout and caulking on my bathtub pretty soon because of an issue I had in this thread.
I found this video...
...which makes it look very simple.
Is it just a matter of removing the old and applying the new as the video suggests?
Does it have to be completely dry before I begin the process?
How long should I let it sit before I consider the bathtub to be useable?
Should I be using grout or caulking on the corners (where tiles meet tiles) as I noticed in the video is grout and yet mine currently has caulking.
Thanks in advance.
John84 is offline   Reply With Quote
Old 08-09-2011, 06:06 AM   #2
Surfaces that change direction, such as tub/tile or tile corners, expand at different rates, so usually do not hold grout well. Those areas should be caulked. Use a silicone caulk designed for wet locations, such as tubs and kitchens. It has a mildewcide in it to reduce mold problems.
The Following User Says Thank You to Just Bill For This Useful Post:
John84 (08-13-2011)
Caulking large gaps in shower enclose+to caulk or grout a tub with tile. pilsengirl Plumbing 1 07-31-2011 12:36 PM
waterproof shower grout Captflx Plumbing 11 03-13-2011 09:21 PM
caulking shower stall questions, removal, grout sealing etc detyianni Plumbing 0 11-29-2010 09:00 AM
Grout, caulking or both??? upinsmoke Plumbing 21 06-01-2010 09:13 AM
silicone caulking over ceramic tile grout joints tonyg2 Flooring 5 11-16-2008 08:48 AM
