#1 |
New driveway
Had a new driveway poured and now I have a 4 foot long gap about 3/8" wide between driveway and foundation that didn't get sealed with the felt (not sure what it actually is) strip. Now water leaks into my crawl space. What can I use to seal the gap between foundation and driveway. Keep in mind that the felt is there it just doesn't seal. It looks like the foundation wall has a slight bow in it and that is the reason for the gap.
#2 |
New driveway
The is a company called Sika that makes a tenacious sealer. It comes in 2 size caulking tubes and a few colors. You can use that to seal against water.
You can pick it up at Home Deopt or mason supply stores. There are other similiar products on the market if you can't get that one. Ron |
| The Following User Says Thank You to Ron6519 For This Useful Post: | Coil41 (06-04-2011) |
#3 |
New driveway
Might try this: Deck-o-seal is used on a pool to fill the intentional ~ 1/2 gap between the pool coping and contrete walkways. Lasts for years, flexible, etc. Available at any pool supply local or online. http://www.deckoseal.com/
| The Following User Says Thank You to vsheetz For This Useful Post: | Coil41 (06-04-2011) |
| Display Modes | |
| re: replace asphalt driveway. best method?? | gramps416 | Building & Construction | 12 | 05-24-2011 12:50 PM |
| Concrete Driveway - Asphalt Over Top? | mark2741 | Building & Construction | 1 | 03-22-2011 04:42 PM |
| Bad driveway patch and seal work | fastfan | Landscaping & Lawn Care | 1 | 09-09-2009 09:14 PM |
| Bury my old driveway problems? | kingcire | Landscaping & Lawn Care | 3 | 08-10-2009 05:47 PM |
| Need to have driveway paved and graded | Mikey Palmice | Landscaping & Lawn Care | 3 | 05-20-2009 08:07 PM |
