New Construction Of Garage - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 10-05-2007, 07:42 PM   #1
New Construction of Garage
Concrete contractor "forgot" to put in anchor bolts for my wall, concrete has now cured, what's the best way to now anchor my sill plate to the concrete.
Thanks Bill
smokymtnbill is offline   Reply With Quote
Old 10-05-2007, 08:50 PM   #2
remodeling pro
Interior wall, drill and use deformed shank pins, "Rawl" brand. Exterior wall will need wedge anchors if code allows in your area, some areas will not accept anything less than anchor bolts sets in the wet concrete.
troubleseeker is offline   Reply With Quote
Old 10-06-2007, 12:48 PM   #3
General Contractor
joasis's Avatar
IRC codes allow for "wedge style" attachments to concrete....impress the inspector with 1/2 inch bolts 6 inches long, and follow the guidelines for is a standard that we anchor each side of a corner, each side of a jamb, and work out spacing on walls to 6 feet or so.
BTW, I build new homes and I do not use J bolts. We drill and set wedges.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Crazy Garage Extension, Building over blacktop?!?! commissure General DIY Discussions 4 09-13-2007 11:09 AM
Converting Carport to Garage viking1974 Building & Construction 2 08-12-2007 10:38 PM
Garage Construction - reference information in_the_woods_nh Building & Construction 3 01-27-2007 03:23 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 02:09 PM
