New Ceiling In Old Plaster House - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 11-01-2009, 10:10 AM   #1
new ceiling in old plaster house
We have a 1920's bungalow with lath and plaster ceiliings. The ceiling was cracked and i have removed the plaster; the lath remains to hold up the blow-in attic insulation. Installing sheetrock directly over the lath seems problematic since there is a small residual amount of plaster that creates a slightly uneven surface. Any ideas on what we should do to create a nice flat surface for the sheetrock? Thanks!
Steve Burke is offline   Reply With Quote
Old 11-01-2009, 10:36 AM   #2
Sight unseen, the only suggestion I have would be to screw full 1 X 3 through the lathe and into the joist, shim as needed to get the entire ceiling flat. Then screw the drywall into the 1 X 3.
Someone else may offer another idea.
Shamus
Shamus is offline   Reply With Quote
Old 11-01-2009, 12:34 PM   #3
Shamus, thanks for the idea. we had considered Hat Track but it looked more expensive and more involved than just running 1x3.
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
rounding transition in attic ceiling plaster luci468 General DIY Discussions 2 05-28-2009 08:28 AM
low VOC paint remover for painted plaster walls and ceiling diy888 Painting 5 03-16-2009 04:10 PM
Cement, plaster, paint - ceiling: "spray skim coat"? BradG Painting 1 11-18-2007 06:06 PM
Plaster removal decision Sarai Remodeling 2 09-08-2006 03:15 PM
