Need A Temporary Mailbox - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-19-2012, 11:00 PM   #1
Rewards Points: 81
Need a temporary mailbox
So some jerk just decided to hit my mailbox with his car. I need to build a temporary until spring. I live in central Wisconsin. I have a mail box and two of those newspaper type plastic boxes.
What's my best bet? A bucket full of sand or gravel and some 2x4?
I'd like it to stand until May without having it tip over all the time.
Total Tool is offline   Reply With Quote
Old 01-20-2012, 08:50 AM   #2
biggles's Avatar
drive a piece of tinwall(electrical tubing) or galv.pipe into the ground and clamp either onto it watch for gas/water lead in from the street...might be a ggod time to pull it back onto the house if you don't need a court order from the PO..you'll never see mail if they have to walk the driveway.cut a 2 X 4 to a sharp point and hammer it in for now OR... http://www.mailboxes.com/departments...FYFx4Aoddy2EnQ
Old 01-20-2012, 09:24 AM   #3
DIY staff
Rewards Points: 7,174
I've seen folks use a wooden saw horse with good results---might need to build one yourself to get the height needed---
Total Tool (01-20-2012)
Old 01-20-2012, 11:37 AM   #4
Concrete & Masonry
Rewards Points: 526
That will likely be the easiest, although you may need to tip it up once or twice if the snow from a plow truck get's it.
jomama45 is online now   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Old 01-20-2012, 12:03 PM   #5
concretemasonry's Avatar
Rewards Points: 2,578
Another vote for the big tub of sane and a couple of 2x4s. Dump some water into the sand to get everything held together for a while. You still have another couple of months of winter.
No way are you going to drive anything substantial into the ground now with lack of snow and the frost depth.
When you rebuild in the spring, since it has been hit once, it could be hit again, so consider a swing away mount or some sort of break-away set up that is easier to fix. There are always people out of control in the winter or snow plows with poor visibility.
Dick
concretemasonry is online now   Reply With Quote
The Following 2 Users Say Thank You to concretemasonry For This Useful Post:
oh'mike (01-20-2012), Total Tool (01-20-2012)
Old 01-20-2012, 11:08 PM   #6
Rewards Points: 81
I ended up using what I had laying around which is 5 gallon bucket, pea gravel and then I topped it off with water. Should get me through until the spring thaw.
The Following 2 Users Say Thank You to Total Tool For This Useful Post:
Colbyt (01-21-2016), oh'mike (01-21-2012)
Old 08-01-2012, 04:57 AM   #7
Getting a new mailbox is a better idea than renovate the older mailbox. Because I think that we should purchase a new thing instead of spending so much money on the older one.
tonnygarden is offline   Reply With Quote
Old 01-21-2016, 04:14 PM   #8
Rewards Points: 2
Use a Ground Anchor
You can use a metal anchor and attach your wood post to that. It will go into the frozen ground with no problem.
See here: diymailboxes.com/install-a-mailbox-post-in-winter/
txag05 is offline   Reply With Quote
Old 01-21-2016, 05:56 PM   #9
joed's Avatar
Rewards Points: 11,990
Three year old post. I hope he got his mail by now.
The Following User Says Thank You to joed For This Useful Post:
craig11152 (01-26-2016)
Old 01-26-2016, 12:44 PM   #10
Rewards Points: 18
I would think so
backdown00 is offline   Reply With Quote
If vinyl planks are a temporary flooring how temporary? mommiemara Flooring 0 09-14-2011 11:14 AM
Help with Temporary Support Needed DIYerIT Carpentry 3 05-12-2011 02:46 PM
Temporary support ideas for temporary beams? WillK Building & Construction 10 03-18-2011 09:37 PM
Reasonable cost to replace mailbox and light post? akphs Off Topic 1 04-26-2010 10:55 PM
Temporary wall support question discojv Building & Construction 7 01-25-2009 08:23 PM
