Need Some Help With Insulation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-27-2008, 05:18 PM   #1
need some help with insulation
Hi, just looking for some advice. While remodeling our bathroom my wife and I recently discovered that our attic has only about 2 inches of blown in insulation. We're thinking that we should put in more but neither of us are sure of what the correct course of action should be. Should we remove all the insulation and put in new stuff? If so, then what type? Or should we insulate over the original blown in stuff that's there? Any advice would be greatly appreciated.
Thanks!!
Niffty is offline   Reply With Quote
Old 01-27-2008, 05:46 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
No need to remove what is there, just add to it. Dependant on the region of the country (climate) you are in, that is what dictates the amount of insulation you need to install and the thickness it should be at.
Please read over the information here: http://www1.eere.energy.gov/consumer...nsulation.html
- Build Well -
Old 01-27-2008, 09:34 PM   #3
I wrote a blog about attic insulation if you want to check it out it talks about insulating over pre-existing insulation. the more that you have the better the r value so keep it there. if you want to check out the blog the url is http://www.pshomehelp.com/2008/01/18/installing-attic-insulation/
PSHome is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 03:13 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
is there a payback for higher level insulation? walenta Building & Construction 2 10-25-2007 02:07 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
