Need Some Help With Bathroom Walls - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-23-2011, 11:21 AM   #1
Rewards Points: 91
Need some help with bathroom walls
Well, I am in the process of removing the wallpaper from my bathroom. If you look at the photos below, you will see I have not done the best job. Bottom line, the paper layer of the drywall was torn off in many places.
Here is what I am wondering:
1) Any way I can sand the walls, paint over them, and still have it look good?
2) Should I remove the paper layer entirely and paint over the brown layer?
3) How about floor-to-ceiling wainscoting -- has anyone tried that? is there bathroom-safe materials they use for it? would i have to prep the walls in a major way?
any alternative ideas are much appreciated! thanks!!
Need some help with bathroom walls-img_1949.jpg   Need some help with bathroom walls-img_1950.jpg   Need some help with bathroom walls-img_1951.jpg
19mquinn79 is offline   Reply With Quote
Old 04-23-2011, 11:58 AM   #2
Did you prep the wallpaper for easier removal? If not go get some Diff from a home improvement store and apply liberally to your walls. Follow instructions on bottle form there. You should consider a hudson sprayer for easiest application of Diff/water solution. Completely remove wallpaper including brown layer, then use a course sponge with warm water and soap to clean walls. Spackle/mud as needed. Good luck!
Rick
http://myhandyadvice.blogspot.com/
sharpsport is offline   Reply With Quote
Old 04-23-2011, 01:07 PM   #3
rip it down
My suggestion is to rip the wall down and put up new drywall. Drywall costs about 5 dollars a board.
Once the paper layer of the drywall is ripped off the drywall is no good. If you just apply a skim coat to the drywall, it will eventually get cracks and flake.
Do it right the first time.
novanoel is offline   Reply With Quote
Old 04-23-2011, 02:43 PM   #4
Handyman
Rewards Points: 512
Don't ya just HATE it when people wallpaper over un-prepped drywall...I would tend to agree..new drywall.
canadaclub is offline   Reply With Quote
Old 04-23-2011, 04:13 PM   #5
Yeah, I agree.
Old 04-23-2011, 06:30 PM   #6
DIY staff
Rewards Points: 7,174
If you choose to save the damaged drywall----Prime the board with an oil based primer before adding any mud to the damaged paper. (This is to keep the damaged paper from bubbling)
Use green bucket mud(all purpose) for the first coat.(It contains glue and will stick to the old work)
Use blue bucket for the final coat (Light weight) as it is easier to sand.--Mike---
Old 04-23-2011, 06:50 PM   #7
Handyman
Rewards Points: 512
I was thinking the same thing Mike but skimming isn't always easy for DIYers.
Old 04-26-2011, 05:14 PM   #8
Skimming is very difficult to master if one doesn't do it often. There is definitely a learning curve.
Old 04-26-2011, 05:34 PM   #9
DIY staff
Not easy for the pros,either. I usually replace the damaged goods.
Fiberglass insulation in a bathroom walls? sukhenkoi Insulation 3 04-11-2011 12:36 PM
Bathroom Walls and Ceiling Become Cracked and Hazy ChantillyScott Painting 2 03-02-2010 01:20 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
Making Walls Plumb in Bathroom Reno cbj8585 Building & Construction 4 05-20-2009 03:48 PM
Bathroom Ceiling and Walls. Drywall ok? atilla137 Building & Construction 11 10-26-2006 03:32 PM
