Need Some Advice And Input - General DIY Discussions - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-04-2013, 09:54 AM   #16
Rewards Points: 5,974
Also double check where the hot water heater leaked because in the older mobile homes the sub floor was particle board whice is fine unless it gets wet.
Old 01-04-2013, 09:54 AM   #17
Rewards Points: 578
and we already moved the trailer, when we first bought it. We only ended up paying $1550 to have that done.
TrailerParadise is offline   Reply With Quote
Old 01-04-2013, 09:56 AM   #18
Rewards Points: 578
the floors are 5/8" plywood, the floor is weak right there where the tank was sitting but that is simple enough to fix.
Old 01-04-2013, 09:58 AM   #19
Rewards Points: 578
the way i figure it, we will need to buy about ten 10' CPVC pipes to rerun the water supply lines, then ten more to run a line to the road to hook into the meter. The only part im not entirely sure about is from the floor up, but i assume ill be able to find a book somewhere with accurate depictions of those plumbing lines.
Old 01-04-2013, 10:31 AM   #20
Rewards Points: 3,130
You do not want to use cpvc from the meter to the house. Use the 1-inch black stuff that comes in rolls.
The Following User Says Thank You to md2lgyk For This Useful Post:
jbfan (01-04-2013)
Advice on finishing my basement? jakec202 Remodeling 1 07-06-2012 03:11 PM
Sub panel load and advice TimMauriello Electrical 2 10-11-2011 06:19 PM
Need advice for kitchen cabinet harware! sychopants Carpentry 11 10-19-2010 01:24 PM
Cedar Wood Painting - Professional Advice meenxo Painting 2 09-08-2009 06:21 AM
Help for painting trim and doors: We need your advice! AaronandSteph Painting 2 01-01-2007 10:16 PM
