Need To Replace Light - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-16-2011, 02:36 PM   #1
cyc
Need to replace light
...but can't get the cover off LOL
Maintenance man has tried. Several friends have tried. We've tried twisting, lifting, pressing, pushing, sweet talking. No luck. It's not stuck - it moves a little. Just can't figure how to get the darn thing off.
Any thoughts short of a hammer?
cyc is offline   Reply With Quote
Old 08-16-2011, 02:46 PM   #2
Rewards Points: 6,652
How hard is it to just press on the side of the cover to allow it to drop. That is how they are made for the light lens to be removed. As for your maintenance man, if he can not get that cover off as simple as it is, I would not be calling to fix anything.
Old 08-16-2011, 02:48 PM   #3
Rewards Points: 5,336
If you push the lens up into the housing, does it expose any hardware? It would have to lift at least 1 1/2".
Ron
B. Franklin 1759
Old 08-16-2011, 03:23 PM   #4
Tizzer's Avatar
Rewards Points: 460
When I scroll in on that top left corner of the fixture, it looks like a hinge. Meaning that panel swings open.
Tizzer is offline   Reply With Quote
Old 08-16-2011, 03:28 PM   #5
That is actually the seam, when they form it on a press.
Old 08-16-2011, 03:37 PM   #6
Tizzer's Avatar
Rewards Points: 460
Zoom in on the second picture. There isn't one on the right.
Old 08-16-2011, 03:39 PM   #7
Pull the white housing straight down. There's probably 2 sets of spring wires that go into the house in the ceiling. Sort of like the cover of a bath fan. Once dropped, squeeze the wires together to release it from the ceiling housing.
Ron
B. Franklin 1759
Old 08-16-2011, 03:42 PM   #8
Code05's Avatar
Rewards Points: 1,104
I agree.
Code05 is offline   Reply With Quote
Old 08-16-2011, 03:46 PM   #9
That would be because when it starts out as a flat piece of metal, they form it into a open faced box, with lips on the bottom and top faces, which ends up being one seam. They usually leave a lip that allows a spot weld to hold the whole contraption together.
Old 08-16-2011, 03:51 PM   #10
Ron, that lens should have a flat face, that holds it around that lip on the metal frame. It is enough that it holds it, but you can press on the side or slide over enough to allow you to remove.
Old 08-16-2011, 04:20 PM   #11
Tizzer's Avatar
Rewards Points: 460
Originally Posted by Code05 View Post
I agree.
Instead of agreeing, go try it. Got a step stool? That ain't no spot weld, but a hinge. Open that and the grey panel slips out for access to the light bulbs.
But I'm not there to actually see it.
Old 08-16-2011, 04:44 PM   #12
You know tizzer, after I looked at it in paint, that does appear to be a hinge on that second picture. Did not look at it before, due to was looking at the post on the phone, which did not show it well.
Old 08-16-2011, 05:26 PM   #13
A Little Of Everything
Rewards Points: 1,364
I think Tizzer might be on to something.
When I try to zoom in, the picture pixelates too much to see it clearly, but it sure looks like that top right corner is more than just a bend.
DrHicks is offline   Reply With Quote
Old 08-19-2011, 01:41 PM   #14
Tizzer's Avatar
Rewards Points: 460
How'd the fixture cover go?
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
new light to existing switched light sirsparksalot Electrical 4 04-22-2011 03:23 PM
New Light Fixture won't turn off Aubullion Electrical 4 02-22-2011 12:23 AM
How much and how difficult to replace a kitchen light ballast? Godzealot Electrical 5 02-02-2011 07:17 PM
Reasonable cost to replace mailbox and light post? akphs Off Topic 1 04-26-2010 09:55 PM
