I just noticed a slight swelling at a fairly new postform countertop miter joint. A glass of water spilled and water laid on it over night and now a spot about 6" long has started to swell.
Is there any way to recompress the particle board using heat and pressure...or some other method?
not so fast, guys.... i DID a repair similar to this and it worked.
however, i had ideal situation to allow the repair. it wasn't swelled that bad, was still wet, and close to an edge by a drawer i removed.
you need a large c clamp and a couple scraps of good wood above and below. i did not attempt to dry it first, i just clamped it tight and left it for a few days. it dried and lined right back up again, hardly noticable.... however, this is not possible in most cases, i'm sure.
DM
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
