Need To Match This Texture (pic) - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 01-09-2009, 10:55 PM   #1
need to match this texture (pic)
hey all,
first post here. i'm trying to match this type of texture and was wondering what the best way will be.
i have a hopper i'm going to use. how thick should the mud be? what size of "drops" do i want to get on the wall? air pressure?
any help would be great!
thanks!
http://i349.photobucket.com/albums/q...7/IMG_3446.jpg
http://i349.photobucket.com/albums/q...7/IMG_3445.jpg
norcalsurfer1977 is offline   Reply With Quote
Old 01-10-2009, 01:46 PM   #2
to match this texture,depending on the size i would suggest that you put your air compressor at 18-20psi of consistant psi. add about 1/2 gal of water to a box of all purpose drywall mud and mix well. and use your large tip on your hopper. spray in horizontal motion over lapping each one with the other. spray and wait about 10 minutes. then drag a large taping knife lightly over in all directions. after it has dried completely lightly sand with fine sanding sponge. if you got a spare piece of drywall it don't hurt to test your skill"s first.
rayscottcompton is offline   Reply With Quote
Old 01-10-2009, 03:26 PM   #3
Rewards Points: 85
I Think your going the wrong way with this. I believe it's called a "skip-trowel" finish. Not hard to do but very labor intensive. Take a look at the photos on this site http://www.drywallschool.com/knockdown.htm and see if its what your looking for.
Best of luck with the project, rredogg
rredogg is offline   Reply With Quote
Old 01-12-2009, 08:46 PM   #4
Rewards Points: 109
I think most call it knock down. The link rredogg provided is a good source. Pics of most @ http://www.drywallschool.com/textures.htm
Daltex is offline   Reply With Quote
Old 01-15-2009, 04:07 PM   #5
Send a message via Yahoo to tzu12lyon
For your texture match
Look for a product called Armor Faux very cool and very easy to apply, a three step process that can create any texture effect that you would like from Tuscan, Travertine, Fresco, and the Striae look. Have had a lot of success for those who need to match texture looks from ceilings to walls.
tzu12lyon is offline   Reply With Quote
Old 01-15-2009, 05:31 PM   #6
SNC
It used to be that they would throw a small handfull of sand in the mud and then spread it on the wall
SNC is offline   Reply With Quote
Old 01-17-2009, 10:39 PM   #7
I always go for professional advice...
try them and you'll be amazed of what they can do.
anyway I know that a lot of people here are good in this area. wait and see.
b3stcontractor is offline   Reply With Quote
Old 01-21-2009, 07:08 AM   #8
Home Improvment Contactor
This is a knock down texture. Size of hole on your hopper, trial and error until you get the right size of spots. Consistancy, follow the directions. You can add or subtract a little bit of water. Too much, sags. Too little won't spray. Air pressure, 20 - 40. Again trial and error. Do all your tests on a scrap piece of wallboard.
Jack of most is offline   Reply With Quote
How to achieve this stucco texture? --pix inside... Kooter Building & Construction 2 08-26-2008 07:24 AM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 12:16 PM
Smoothing out skip troweled wall texture wem Remodeling 2 03-03-2008 12:57 PM
Whats the best way to remove orange peel wall texture? billyg Carpentry 2 01-30-2008 05:09 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 04:38 PM
