Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 11-19-2012, 01:00 PM   #1
need help upstairs tub/shower is leaking into downstairs kitchen
Just recently bought first home. Upstairs shower gas been used only a handful of times but today it started to leak. Was planning on doing some demo up there anyways but wasn't at the top of the list...what should I do to troubleshoot the leak I am good with my hands but don't have much plumbing experience
travisdavis is offline   Reply With Quote
Old 11-19-2012, 01:15 PM   #2
Super Moderator
Here are the most common tub/shower leaks--
Water on the floor from curtain or tub door
Leaking shower arm---remove valve cover plate for valve and look in the hole---
Leaking gasket at tub over flow---over fill the tub to check---silicone caulk and tighter screws to fix--
Tub spout leaking out the back and squirting into wall----replace spout---
Leaking valve/mixer cover plate---tighten and caulk the top of the cover only.
Leaking mixer valve---remove cover and look---
Leaking drain set--P-trap---or old barrel trap cover ---open up the ceiling under the tub and look--
A snake camera is handy when trouble shooting----a wad of paper towels on the end of a wire also works---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
sdsester (11-19-2012), travisdavis (11-19-2012)
Hot upstairs but cold downstairs Barton6435 Plumbing 2 12-20-2010 09:08 AM
help: distance from upstairs toilet vent stack to a new downstairs 1/2 bath Heikks2002 Plumbing 3 01-15-2010 11:21 AM
upstairs bathroom leaking down 4" main amakarevic Plumbing 11 07-01-2008 07:57 PM
Urgent help on leaking bath tub to kitchen surepan Plumbing 6 05-05-2008 06:39 AM
HELP - Tub/Shower Combo Leaking Betty Mac Plumbing 1 03-29-2008 09:43 AM
