Need Help With Reparing Wall/plaster Texturing - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 08-16-2008, 06:01 PM   #1
Need help with reparing wall/plaster texturing
Hi,
Thanks in advance for your help. I had some foundation problems that were dealt with over a year ago. They resulted in this crack in my wall (see photo). I filled in the crack with silicone. I attached a picture of the plaster texture of the wall. My questions are:
*do I need to further prep the wall before start applying plaster (as you can see, I started to apply plaster but quckly stopped), i.e. do I need to put tape on, etc.
*do I have to use plaster? can I use joint compound? based on the pic of the texture, what would you recommend?
*based on the pic of the texture and the crack, what would you recommend for steps and tools to apply the texture?
I do realize that a pro could make this look like new but I simply don't have the budget (wedding and new kitchen to pay for). Additionally, this place will be a rental in the near future and I am not too concerned about asthetics. So any thoughts? Thanks!
Need help with reparing wall/plaster texturing-007.jpg   Need help with reparing wall/plaster texturing-006.jpg
cdunbar is offline   Reply With Quote
Old 08-16-2008, 10:24 PM   #2
Rewards Points: 1,232
<Shakes head>
<Walks away>
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 08-17-2008, 07:19 AM   #3
The silicone application, well....it might have appeared to be a good idea at the time, but unless you are willing to remove it as part of a proper plaster repair I don't think any long term restoration is going to be satisfactory. ( The problem is adhesion to the silicone).
If you want something that you won't have to fix every year (remove the silicone.) search PLASTER CRACK REPAIR many detailed great posts on this site.
or play with "fresh start" soupy joint compound, a brush, a sponge, and paint. Then you can try something else next year.
good luck
Big Bob is offline   Reply With Quote
Texturing over painted walls l1r Painting 3 08-05-2008 10:52 AM
Texturing a Previously Wallpapered Wall shapeshifter Painting 4 03-16-2007 04:14 PM
Texturing a ceiling swhalen Remodeling 1 04-26-2006 06:20 AM
