Need Help Locating This! (Vinyl Mesh) - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-06-2011, 08:28 PM   #1
Need help locating this! (Vinyl Mesh)
I've been searching the internet endlessly (or so it seems) for a high quality vinyl mesh. I use it in a project, and need a lot of it. I've been using Gutter Guard (a product by amerimax), but their product has become extremely inconsistent, and cheap. Prior to them changing their product, it was PERFECT for what I needed. Here is a picture of their same product, just two different batches:
I need a black vinyl mesh that is very similar to mesh #1 in the picture. Does anyone know of a place that I can get it? Mesh #2 is too cheap, and can't be used for my project.
Thanks for any help!
Evyllchyld is offline   Reply With Quote
Old 07-06-2011, 09:46 PM   #2
Rewards Points: 600
Try writing to, or emailing, Amerimax. Maybe they have 2 manufacturers for their mesh and can tell you where to buy the one you need. Or maybe they sell your sample #1 at one of the big box stores and #2 at a different chain of stores. It can't hurt to ask them.
gma2rjc is online now   Reply With Quote
Old 07-06-2011, 09:50 PM   #3
They were all purchased at the same Lowe's, and some are even brown. But contacting Amerimax directly may not be a bad idea. I will do that while I continue to look! Thanks so much for that idea.
Old 07-07-2011, 08:09 AM   #4
Rewards Points: 3,130
Look at vinyl poultry fencing. Looks almost the same. Probably cheaper too.
Old 07-07-2011, 09:38 AM   #5
We are getting closer! lol. I guess I forgot to list the dimensions of the holes. They are each only 1/2" wide. Poultry fencing seems to have 1" holes. But yes, very similar. I'm going to keep looking in that direction. Thanks!
Old 07-07-2011, 11:59 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Look in the ceramic tile/flooring department of any home center. Several companies offer that product to be used in conjunction with Self Leveling Compounds.
Mapei International has one, Laticrete International has one, Custom Building Products has one, there are several others.
http://www.mapei.com/public/COM/prod...ath_TDS_EA.pdf
XXX
Old 07-07-2011, 12:09 PM   #7
I'm literally leaving right now to check it out! I'll be back in a bit with hopefully, good news! lol
Old 07-07-2011, 12:10 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That stuff is all over the place in the world of tile installations, you just have to know where to look. Good Luck!
XXX
Old 07-07-2011, 12:11 PM   #9
... Or not, I forgot someone hit and totaled my parked car last week. I will have to check it out later tonight. Haha
Old 09-02-2011, 05:11 PM   #10
Well, I got my hands on this, and there are just too many issues with it for what I need it for. Does anyone else have any suggestions?
Old 09-02-2011, 05:44 PM   #11
mossypath's Avatar
Maybe if we knew what you are using it for we could be a better help to you.
Might want to try a supplier for stucco products. They have some neat things to work with.
mossypath is offline   Reply With Quote
Old 09-02-2011, 08:49 PM   #12
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I saw something similar at a restaurant supply company.
Link provided just as an example.
http://www.webstaurantstore.com/blac...sh/208768.html
Old 09-02-2011, 09:13 PM   #13
fabrk8r
fabrk8r's Avatar
Have you tried McMaster-Carr?
They have vinyl, plastic, poly, neoprene mesh in many different size configurations and thicknesses.
I found the a polyethylene mesh (black) with your dimensions in stock in 4' widths and up to 50 linear ft.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 01:04 PM
vinyl sheet or tile (or allure) over old vinyl? thomase Flooring 8 06-30-2008 05:15 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
