#1 |
Need help with garage storage
I am looking for a creative and hopefully inexpensive way to store a crib in my garage. I am running out of floor space and would like to store the crib on the wall or ceiling. The crib measures 4'x3'x8". Most of the storage systems sold are way out of my budget. Thanks..this is a great site.
#2 |
Experienced
A vesectomy is better.......
, just a bit of humor.4 eye bolts, 2 on the bottom, 2 on the top screwed into studs and some 1/4" rope will do the job easily.
When its all said and done there is usually more said than done To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Good idea...can you recommend a knot...I'd be afraid the rope would come loose and the crib would fall on someone.
#4 |
Experienced
Bowline on the bottom rings, loop through the top rings and then back though the bottom rings with a half hitch, will not fall.....
#5 |
A "Handy Husband"
2 big storage hooks screwed into studs, hang the crib on the hooks.
#6 |
Average Joe/ex-Navy IC3
If the sides slide down, or a older one, you may as well toss it. Crib rules change every year, and by the time you want to use it next, or someone wants it, the CPSC will change the rules on safe crib use. If still wanting to store, dismantle it, and just wrap in plastic, and store in your basement, or out of the way until Garage sale time in the Spring.
#7 |
Coconut Pete's paella!
Is it a detached garage with open rafters or an attached garage w/ a drywall ceiling?
I have a detached garage w/ open rafters and I've got a crazy amount of stuff nowhere near the floor. It's a little easier since You can just put boards down up there and slide stuff onto them. |
| Display Modes | |
| Building Garage overhead Storage | swenard | Building & Construction | 15 | 01-23-2012 03:01 PM |
| Garage ceiling storage with Open Web joist system | BillyDIY | Building & Construction | 1 | 07-29-2010 12:30 AM |
| Garage storage, attaching to engineered beams | jdcook72 | General Discussion | 6 | 06-17-2009 12:01 AM |
| building storage in garage | m98cox | Building & Construction | 5 | 04-13-2009 06:39 PM |
| Garage ceiling and attic storage | DIY KEN | Building & Construction | 7 | 01-06-2009 05:57 PM |
