Need Help Diagnosing Broken Garage Door Opener - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 02-12-2009, 11:31 AM   #1
Rewards Points: 12
Need help diagnosing broken garage door opener
-Lift Master 1/2 HP Security +
-press button one time, nothing. Press again, motor makes noise like it is turning but chain drive doesn't move whether door release is latched or unlatched.
Halp?
Klamath is offline   Reply With Quote
Old 02-12-2009, 12:35 PM   #2
Rewards Points: 5,336
Check the sprocket on top of the motor. If it doesn't turn when you hear the motor run, the shaft might be broken. The sprocket could also be stripped.
How old is the unit?
Ron
Old 02-12-2009, 05:35 PM   #3
Halp?
Unplug the unit. Take the top cover off and look at the chain sprocket as previously stated. If it looks okay, take off the case and see if there are pieces of debris from the drive gear laying in the cover. Look at the drive gear and see if the teeth are stripped. This is where I would start first.
If the sprocket is broken or gear is stripped then your door is in need of balancing, new springs, or rollers because it is binding somewhere or too heavy for the GDO. The GDO is not made to actually 'lift' the door--the springs do this. Correct the door problem before you replace the GDO parts/new opener.
afollower is offline   Reply With Quote
Old 02-13-2009, 04:48 PM   #4
I agree with afollower.
Most drive gears/worm gears/etc are plastic or a combination of metal meshing with plastic. Eventually something is going to wear out.
If the door isn't balanced it will tear up a new opener.
Shamus
Shamus is offline   Reply With Quote
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 05:57 PM
Garage door twisted, broken by opener... xray328 General DIY Discussions 9 07-19-2007 05:06 PM
Broken garage joists RBoncelet Building & Construction 4 11-05-2006 10:23 PM
Broken garage joists RBoncelet Carpentry 5 11-05-2006 01:55 AM
