Need Help! - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-24-2011, 08:33 PM   #1
Need Help!
My Garage has jumped off track and cocked. One cable is completely off & the other has lots of tension. What can I do the just get the garage down and keep the Elements out
Alcarte is offline   Reply With Quote
Old 07-25-2011, 06:20 AM   #2
Did one of the cables break, that is usually the case. Several strong bodies can usually reset the door once all the spring tension is removed. If no help available, you may have to take the door apart and reassemble it. While it is apart, install new cables, and ALWAYS install spring safety cables for extension springs.
