Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > General Discussion
Old 04-18-2010, 02:52 PM   #1
fastback4's Avatar
Need to drill Corian
I have to support my built in dishwasher to the bottom side of the counter top and need to drill a hole. Can i drill Corian with a standard drill bit or what else?.........Tom
fastback4 is offline   Reply With Quote
Old 04-18-2010, 03:32 PM   #2
Civil Engineer
Ordinary tool steel bits work fine. Just make sure you put a stop on the bit, so you don't drill through the top of the counter.
Old 04-18-2010, 04:19 PM   #3
Many dishwashers have a side cabinet mount option. The straps on the top can be moved so you're drilling into the cabinet face frame. If your dishwasher has the option, I would use it.
Ron
Old 04-18-2010, 06:27 PM   #4
fastback4's Avatar
Forgot to ask...Do i use a flathead wood screw? Do i use one of those cone shaped inserts like the plastic one you see for hanging a picture on drywall?
Old 04-18-2010, 08:39 PM   #5
Super Moderator
No plastic insert!---How thick is this top? Often they are 'skins' of corian over particle board.
Any way--drill your hole--oversized for the panhead screw---glue in a wood plug made out of a bit of cedar shim--then screw in the dish washer.Wood will crush and not crack the Corian.
Or do as Ron suggested--move the top clips down to the side slots and screw it into the cabinet face frame.--Mike--
Old 04-19-2010, 11:29 AM   #6
fastback4's Avatar
I did not know i could move those clips. I think i'll do that instead of drilling the Corian. The top is 1" thick...
The Following User Says Thank You to fastback4 For This Useful Post:
oh'mike (04-21-2010)
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 04:18 PM
Rookie needs advice - How to remove old thinset from concrete floor? rookie floor layer Flooring 9 10-04-2009 01:01 PM
Determining correct drill key MRTIGRE General Discussion 3 06-04-2009 02:58 PM
Bosch GSB 16 RE drill Coxy Tools 0 05-28-2009 02:46 AM
