Need To Dig A Ditch. Recommendations? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 07-25-2012, 10:59 AM   #1
Rewards Points: 272
Need to dig a ditch. Recommendations?
I'm converting my overhead electrical service entry to an underground service entry. I have a 55' run from the meter box to the electrical pole. It's basically a straight shot. There are a few obsticles howevver, first is a gutter drain that I will need to go under/over and the other larger obstical is my driveway. The driveway is probably 12' wide and is an older lowgrade asphalt. It won't break my heart to rip a path through it but I'd prefer to do it as cleanly as I can. My original plan was to have my brother in law use his excavator to dig the ditch but the smallest bucket he has is 18" wide. Seems kinda overkill for a ditch that will only have one 3" and one 1" conduit ran through it. So I've contemplated either renting a 4" or 6" ditch-witch or else finding a local contractor with a small backhoe to dig the ditch.
I'm also wondering what is the best way to cross the driveway. If I run a ditch witch through it I suppose it will tear the asphalt all to hell. Is there a way I can cut the asphalt to get a smooth straight line? Are there blades I can put on a circular saw that would cut through the drive? Angle grinder with masonary blade? Or would I need to rent a huge walking concrete saw or something like that?
What would you suggest? I've got all the electrical work done, just waiting to get the ditch dug and conduit buried so I can get an electrical inspection.
speedster1 is offline   Reply With Quote
Old 07-25-2012, 11:50 AM   #2
You could try and rent a hand held concrete saw.
For 12 feet that might be fine, I haven't used a walk behind saw before but I imagine it's a bit better on the back.
tjansen is offline   Reply With Quote
The Following User Says Thank You to tjansen For This Useful Post:
speedster1 (07-25-2012)
Old 07-25-2012, 12:07 PM   #3
Rewards Points: 3,130
You have all the electrical work done? Are you saying the conductors are already pulled? I'd really be surprised if that's the case. I also live in WV (Jefferson County), and the PoCo was responsible for pulling the conductors, connecting them, and installing the meter. All I had to do was put in the conduit.
The Following User Says Thank You to md2lgyk For This Useful Post:
Old 07-25-2012, 12:14 PM   #4
Rewards Points: 272
You are right. What I meant was that I've installed my new 200A meter box/disconnect along with my 200 circuit breaker panel. They are wired together and ready to go. I need to buy the conduit and install a pull-rope so that the PoCo can run the line down the pole, through the conduit, and connect to my meter socket.
Old 07-25-2012, 01:29 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
I'm pretty sure that conduit has to be 3' deep.....
Just rent a trencher....it will cut about a 6" wide trench....
On your driveway....asphalt is pretty soft....if you want it to look pretty...rent the saw...otherwise...break up chunks....
Old 07-25-2012, 05:55 PM   #6
Having done this, but for more like 150 feet, I would not recommend a very narrow trench. Unless your ground is really flat and it's a perfectly straight shot, you'll appreciate some wiggle room afforded by a wider trench. Also, it's easier to glue the conduit together if you can get down in the trench.
drainage ditch stagnant water denemante Landscaping & Lawn Care 6 05-17-2011 11:58 AM
How to Keep Gravel from Washing Out of Drainage Ditch Jaylyn Landscaping & Lawn Care 4 01-27-2011 06:17 PM
drainage ditch NHO Landscaping & Lawn Care 1 04-03-2009 02:37 PM
8 foot perimeter ditch for home defense silverfrost1 Building & Construction 5 09-05-2007 04:43 PM
Building a drainage ditch get outside Landscaping & Lawn Care 5 05-15-2007 02:44 PM
