Need Advice - Repairing Cracked Garage Foundation - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 09-26-2009, 10:05 AM   #1
Need advice - repairing cracked garage foundation
I am planning on insulating and finishing my garage. Before I do it I need to adress this problem. The front corner of my garage foundation has several cracks. The cracks go all the way through and are open enough that water comes through when it rains heavily. What is the correct way to repair this? I am thinking I need to have a professional remove this corner section and repour new concrete. If this is the best route what type of contractor should I call and what should I be asking them to do?
I guess I could always patch the cracks but it would eventually open up again.
beerdog is offline   Reply With Quote
Old 09-26-2009, 10:20 AM   #2
Too Short? Cut it Again!
I have had great luck with the concrete repair and restoration products from this company. They are a little pricey but work as described and perform as promised.
http://www.abatron.com/cms/buildinga...nproducts.html
Old 09-26-2009, 11:50 AM   #3
Advice worth 2 cents!
Rewards Points: 150
As he said. Looks to me like a DIY concrete repair job. Mapeii and Sitka make good products for stuff like this. If it was a house I would say NO WAY but, gee, it's only a garage.
-pete
ps I would also be tempted to use a concrete joint compound like the stuff they use on expansion joints.. Check out Bostik adhesives and compounds
pss... you might want to redo the exterior grading. Make sure the drainage is up to par.
---pete
HandyPete is offline   Reply With Quote
Old 09-26-2009, 01:16 PM   #4
Household Handyman
Rewards Points: 1,408
I agree that the exterior grade needs to be looked at, and maybe the exterior of the foundation needs to be coated also. This would be an excellent time to look into seeing if the crack is all the way through the concrete at that point, and treat/fill the crack on the exterior also. I cannot pull from memory a hydraulic concrete patch, although there are some out there. I would gouge a "V" in the crack,interior/exterior, and clean it out thoroughly before patching for a good bond. A hydraulic type patch may work good in this application. I'm certainly not an engineer, but from the picture I would say there should be no structural problem. Good Luck, David
garage floor, foundation, footer questions? wengr General DIY Discussions 1 03-24-2009 08:01 AM
Cracked cement floor in garage. gante Building & Construction 9 02-26-2009 11:55 AM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
advice for insul./vent. of garage roof? King Dark Lake Roofing/Siding 3 04-15-2007 01:37 PM
Addition Foundation /Build. advice wannabuild Remodeling 3 12-15-2006 06:28 PM
