Need Advice On How To Screw Thru A Duct? - General DIY Discussions - DIY Chatroom Home Improvement Forum
Old 04-08-2007, 11:01 AM   #1
Need advice on how to screw thru a duct?
Hello. I just purchased a new vent cover, but I found that the none of the 8 screw holes on the cover match up to the holes on the duct. I tried using the screws that came with the cover to start new holes, but the screws would not go through the metal. Does anyone know what I can use to start the holes? Thanks for any info.
Chip718 is offline   Reply With Quote
Old 04-08-2007, 12:32 PM   #2
Eibwen
Normally use true sheet metal screws.. I like to use the hex head's with a drill driver. With a slight pressure they will start their own hole in the duct. If the screws you have arent working, maybe try a small pilot hole with a sharp drill bit.
Is this a new vent to let air into a room or a return grille?
Eight holes sounds like alot.
Sammy is offline   Reply With Quote
Old 04-08-2007, 03:13 PM   #3
Thanks for your reply. You are right. It is a return grill.
Old 04-08-2007, 03:28 PM   #4
Eibwen
Your welcome
If your old return grill was just a little old looking, try cleaning it up a little and hitting it with some spray paint. Its amazing how well they clean up if you wash the dust off, sand em a little, and then spray paint them.
DIY Air Duct Cleaning... How to? singforsupper HVAC 5 10-09-2008 01:06 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
Modifying existing duct work Thurgee HVAC 3 04-05-2007 10:35 AM
1000-1400cfm...duct sizing Swordfish215 HVAC 1 01-15-2007 04:22 PM
duct sizing Stu HVAC 2 12-22-2006 06:36 PM
